Old 01-14-2018, 03:54 PM   #1
L79racer
L79racer's Avatar
Default driveshaft speed sensor
Can someone let me know the pin out configuration for the autometer drive shaft speed sensor? I want to use it with my mega squirt ecm. What color is ground, power and signal? I cold not find it on their website. Thanks.
L79racer is offline   Reply With Quote
Old 01-14-2018, 04:10 PM   #2
FED 387
Liked 330 Times in 178 Posts
Default Re: driveshaft speed sensor
Black is ground white is signal red is power that's the way we always run it Fed
Old 01-14-2018, 06:21 PM   #3
L79racer
L79racer's Avatar
Thanks Fed!! Im going to reuse my cable also that went to my tach. The end of the jumper cable at the sensor has a three wire connector but the other end that goes by the tach has a 4 wire connector. Is the fourth pin a shield?
Old 01-22-2018, 08:39 PM   #4
L79racer
L79racer's Avatar
Fed 387 or anyone else tell me what the placement in the connector for the power ground and signal is? looking left to right with clip up just like the picture.. Thanks for the help. Im making up a new cable from the sensor to my ecu.
Old 01-23-2018, 10:33 AM   #5
L79racer
L79racer's Avatar
Ok, have the info I need. Ill post it here in case someone else will need it one day.
Connector has terminals marked A,B,C
A -Blue is ground
B- black is signal
C- tan is 12 volts
