Looking for suggestions on who could help out on getting parts to put a 727 behind a viper v10
Contacted ati with no luck they only make a adapter plate to bolt a gm trans on it Car will be in gt so I can’t run a glide or 400 Any help would be greatly appreciated |
Liked 3,230 Times in 982 Posts
Contact Kevin Helms, he’s built one or two of them.
Liked 10,904 Times in 2,255 Posts
I think first V10's were glide cars. Dave at Pro Trans
Found a 727 that will work that came in the trucks for a couple years before they went to the 518 that all my good parts will work in
On the classracerinfo site it only gives hp rating with a stick at 450 hp no auto listed for the 97 488 v10 So Would it be rated the same with auto ? |
Liked 2,491 Times in 700 Posts
I do not recall any year Viper ever coming with Auto = Therefore NOT legal
for stock class if that what you were planning.
Car is a super stock gt fwd conversion
Liked 11 Times in 4 Posts
I'm intrigued. What FWD conversion chassis, with the lack of firewall relief for any Mopar RWD conversions, does a V10 fit in? Bellhousing adapter wise I though the V10 was the same bolt pattern as a small block but a little research it appears same as the Cummins instead.
Tim Kish 3032 SS/GS |
Liked 460 Times in 91 Posts
Please call Dave Collette 443-807-1569
Bob Bender 144 O/SA 2010-2012 National Record Holder |
Liked 325 Times in 50 Posts
Depends what year motor you are looking at. The 488 bolt pattern will fit a 727 Early Diesel T/Flite I have two cases for that combo. Also depends how you plan on starting it. The later DP with the 513 motor has an an adapter for a GM Glide or T350 and both have different starting methods. Calll me @ 985-804-6161. I have a Viper with a t/f here that is for sale, and I had another. And can probably help you. Jeff Teuton or email jefft@southlanddodge.com
Jeff Teuton 4022 STK |
Thanks guys Got the trans covered now after talking with Jeff that has already done this
