Old 01-02-2018, 10:51 PM   #21
DonatoEng
Liked 8 Times in 5 Posts
Default Re: Hydraulic Thow out bearing
Tom,
I'm putting together a Drag Pak stick with an hydraulic system to try. Using an adjustable stop on the pedal for air gap setting.
John
John Donato Stk / SS 3435
DonatoEng is offline   Reply With Quote
Old 01-03-2018, 07:50 AM   #22
stock1080
Liked 94 Times in 38 Posts
thanks Tom
stock1080 is online now   Reply With Quote
Old 01-04-2018, 02:15 PM   #23
Todd Gross
Liked 54 Times in 24 Posts
Originally Posted by DonatoEng View Post
Tom,
John
Hi John.
You putting one together to race yourself or working on a customers?
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 01-05-2018, 04:18 PM   #24
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Originally Posted by Sean Marconette View Post
You may want to look at the rule book, as I am pretty sure it states no hydraulic or electric. Most convert to linkage as it's easier to get the air gap set correctly and for consistency and another place to adjust for RT. The electric statement prevents stick racers from using a magnet for releasing the clutch pedal in both stock and SS.
Sean
I am building one that is both hyd. and mechanical.
A mechanical t.o. bearing and fork pushed by a hyd. slave cylinder.
I wonder if this is legal ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 01-05-2018, 05:17 PM   #25
Maverick
Liked 36 Times in 26 Posts
I am interested in what your are doing with the hydraulic cylinder, in whether it will be quick enough, and how big a cylinder, and how big the bore on the master cylinder. I run a hydraulic throw out bearing, that uses no fork. I don't run stock or super stock, but it is legal in my class. I don't see many hydraulic systems, except on the new cars. Very controversial. And what type of fluid you plan on using. I don't believe I would call this a hydraulic throw out bearing, I would call it a clutch hydraulic slave cylinder. Hydraulic bearing won't have a fork
Old 01-06-2018, 11:43 AM   #26
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Alan,
I would check with your division tech director and get clarification from them on legality. There are a few reasons why you would not want to run a hydraulic setup even if it's not a class car.
Do you want to go rounds and consistently cut a light? It's hard enough with a mechanical setup to cut a light constantly, then add the reaction rate of the fluid and those components. Depending on the ambient temperature, the viscosity is going to add another factor on your reaction.
Either way, good luck.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 01-06-2018, 10:13 PM   #27
DonatoEng
Its the 009 car that a friend purchased that I'm going to run.
I used an hydraulic system with a fork in my stocker Dakota since I built it in 95. NHRA had no issue as it was the production set up. They did look it over for and solenoid in the system.
John
Old 01-06-2018, 10:20 PM   #28
DonatoEng
John
