Liked 78 Times in 19 Posts
Need some advice for installing an 8.75 in a 79 Aspen. Would a B body rear end be the closest fit for width? Currently has an 8.25. Thanks, Craig.
Liked 3,165 Times in 969 Posts
What kind of power and which class are you setting up for? Early B Body is close but you still have to offset springs and/or move the pads. If you’re going with a lot of power and/or trans brake go directly to a Dana.
Jim Carter 2340 Super Stock 2340 SST/2340 Stock Set another place at the table Last edited by jmcarter; 11-21-2017 at 02:54 PM. |
Liked 44 Times in 21 Posts
68 to 70 B body is the one you need.
Steven Barnes Stock 704 N/SA |
Liked 309 Times in 118 Posts
I put an 8 3/4 from a 71 Charger in a 76 Volare, the locating pins were less than an inch off, I elongated the shock plates with my die grinder, it was almost a bolt in.
Used 69 b B body on my sons 76 volare and it fit without much trouble at all . And I am not a mopar man at all YET. lol Now if I could just find a grill that's what I am having problems with.
Liked 251 Times in 125 Posts
Liked 53 Times in 38 Posts
Find a 66-67 rear, shorter that the 68-70. Doesn't it have to be the same back plate to back plate measurement as the 8-1/4 or whatever was in it?Gotta put axles-spool in anyway, cut it to the right length.
It's a 318 4bbl. N/SA. also toying with the idea of building the 8.25 rear. Just not sure if it will hold up over time. My gut feeling is to go with the 8.75, just a little more hassle to locate the best choice housing and modify it to fit.
Only if you're using the same wheels and tires, which you're not.
