GM 1980 305 w/ stocker cam, 2-3 inch vac.
I cant get a good idle, it loads up and it falling over about 90 ft. out then pickup a sec. later. The carb was built by a local SS racer a few years ago. It has the pri. rods removed. I have to have the throttle open a lot of turns to keep it running. The fuel is being pulled from the mains and the idle screws have little affect. I have tried other Q jet carbs, even a new Jet stage 3. I guess the question is, how do I get this to run right. |
Fuel pressure?
Todd Greene |
Fuel pressure
Started at 7psi I how have it set at 3.5psi. Float is at 1/4 " , have changed float and needle & seat. |
#4 | |
Liked 314 Times in 177 Posts
Liked 320 Times in 102 Posts
Did any carb ever idle on this engine??
Are the primary blades drilled?? 2 or 3 inches of vacuum is nothing?? You might have engine problems and not carb problems.. Such as vacuum leaks, cam timing, damaged valves or too many to list.. Just sayin'
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 10-30-2017 at 11:04 AM. Reason: Spell check pos |
Carb worked on bracket 350. but w/ south a year later. Have rebuilt ,cleaned and blow it out. but has no
I have tried 3 other carbs on the 305. problem on 3 different motors, all low vac motors. smoked all the motors, no leaks, leak down good. plates drilled. the motor will run with a Holley. put a Jet 3 on this motor and still the same. |
Liked 249 Times in 48 Posts
Are you sure you have the right gasket between the carburetor and intake manifold?
I have looked at the gaskets but, I maybe should look at that . thanks
Liked 33 Times in 16 Posts
Yes to this...there is a base gasket out there that is the mirror opposite of what is needed. Will cause a huge vacuum leak for sure.
Rich Taylor I/SA - 321 |
Liked 205 Times in 93 Posts
a huge vacum leak will cause it to be rich? I thought I would make it lean...
