#31 |
I know what hot lapping is. Been doing this for about 50 years now. Mine is faster on 16 volts. I also test.
Ed Wright 4156 SS/JA |
#32 |
Liked 8,202 Times in 1,536 Posts
#33 |
Started in 1962. Back when we drove to the track, changed rear tires, and opened the "dumps". Be 74 next month.
#34 |
The hot lapping Mr Derby City is talking about is called winning rounds late in the day. That is something most racers are never lucky enough to experience. If you have not experienced a late round push to get the racing over with for the day, then you do not know what real hot lapping is. Listen to his advice about running an alternator because he has been there and done that.
#35 | |
#36 |
#37 |
Not saying that I'm any kind of a heavy hitter or anything , earlier this year I doubled up in a local Super pro and local S/ST event with my car that has no alternator but does have two battery's went 5 Rounds in Super pro and won in S/ST. There was only one class between the two classes ( motorcycle ) that was 4 time runs and total of 9 rounds that night. I would put a charger to the car when fueling but had no trouble cooling the car or starting . Towards the end of the evening I was having ( being a old guy) a little energy trouble as the gate time was 5pm and the final in S/ST staged a 2:30 in am..... LOL
The reason I have no alternator was that back when i ran with one third round of a team race the alternator split in half 600 ft out. When it did that it killed my MSD box so I was done that day and had $175 repair on the box. So I just mounted another battery out back and give up on the alternator. It kind of helped my 60 ft. removing weight off the front and putting 45 lbs in the rear..... That's my two cents....
Old Nick in Tucson! Hahaha |
#38 |
Been there. No problem with two 16s.
#39 |
Liked 53 Times in 38 Posts
I haven't bought any 16 volt batteries, but IMO, buying 2, plus the charger is a lot more $$ then one little Toyota junk yard Denso one wire alternator with a big pulley, thats maintenance free, and one less thing to worry about between rounds.
Mike |
#40 |
Liked 237 Times in 126 Posts
Around $1000 for two XS 16v batteries and a charger. $250 for a Powermaster Denso. I run a full size alternator and it killed all my charging issues. I bracket race and now means now.
