#271 |
Liked 18 Times in 7 Posts
Xx
#272 | |
I mean, I'm offended I can't afford to run Comp. I think, to be fair to poor guys like me, NHRA should make some classes for basically Stock engines for guys like me trying to race on their Social Security checks. :-)
Ed Wright 4156 SS/JA |
#273 |
Eddie
#274 |
Same advice to you if you want to run NHRA Stock.
#275 | |
Guest
Posts: n/a
#276 |
Bb
#277 |
Liked 536 Times in 110 Posts
Stock Eliminator is alive and well. We had over 120 cars at the Indy LODRS event last month.
Jim Kaekel 3836 STK |
#278 |
Liked 1,985 Times in 598 Posts
The biggest problem with adding crate motor and Pure stock classes to NHRA competition is that there is already too many different classes in both stock and Super Stock. There is nothing wrong with these two classes but there has to be a line drawn when it comes to the amount of classes. Super Stock is already out of control wit GT. FSS and the modified classes. Modified, Super modified, and the modified trucks need to be moved over to comp and revise the comp class to something that can survive and get a car count. NHRA racing is not for everyone. If you want to race an NHRA class then you have to build or buy a car that fits those classes. Simple enough.
There is no cheap way to drag race at this level anymore.
Mike Pearson 2485 SS |
#279 |
Liked 405 Times in 158 Posts
Heard the same argument from fast cars being beat by cheaper slow cars etc.
Can a crate motor car throw any cam in it? No. Any head? No. Any valvetrain? No. So what makes it a crate motor? Well, you have to run a particular set of parts as per their part number. The carb is a 750 holley for small blocks and 850 for big...can I run any carb on a crate? No! So what's left? Ahhh...the intake. ANY intake is allowed, which is like totally different than a LD340 intake on a ....or a certain intake on 283's....or.... If the rule says "you must run xyz part to be legal" is that a spec or not? Can you deviate from that spec or not? So basically, the fight is about allowing people to use easier to find parts instead of 50 year old cast iron. What if the rule said factory intake and carb? Well then the only difference between a crate motor and a traditional stocker would be the heads. THAT'S IT! And if you can't find 50 year old heads, you ain't gonna find 50 year old intakes and carbs any easier! Wife looked up the coyote crate motor yesterday on amazon, $17,000. I said WHAT??? that can't be right, must include electronics etc but she already had switched so I never got to read it. Would you guys feel better if crate motors cost $17,000 and you couldn't build it yourself? Then the game is again set for the richer ones? Last edited by goinbroke2; 09-18-2017 at 12:03 PM. |
#280 | |
Liked 184 Times in 113 Posts
Did not have any problem creating a class for the COPO Manufacturers built race cars or ProMod for that matter? |
