Old 08-03-2017, 05:29 PM   #351
4406mopar
Liked 120 Times in 53 Posts
Default Re: Important if you run D-H/S or SA
Originally Posted by Greg Hill View Post
What do transmissions have to do with this thread. It's about an Edlebrock manifold that has been recognized as a superseded part that, was not legal for 45 years, and now all of a sudden even though it hasn't been made in 20 plus years is legal.
Greg I'm expanding the mud slinging to show all of you that every make has bogus parts that FIT into the house rules at NHRA.
I don't agree wi it either, along with many other obviously wrong decisions.
So which part is the worst offender, the latest and greatest?
4406mopar is offline   Reply With Quote
Old 08-04-2017, 08:30 AM   #352
Rick Leininger Jr.
All this assumes the LD-340 is worth something. When we did a A-B-A swap/test vs. a OE 71 340 #2100 intake, it was worth a grand total of zero point zero.
Rick Leininger Jr. is offline   Reply With Quote
Old 08-04-2017, 09:54 AM   #353
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Back in the early 70s I did an A-B swap at Hampton Raceway between the stock 69 440 intake and an Edelbrock CH4B, the car ran identical to the hundredth. The engine was a bracket race 426 street wedge with a Holley 4779. I did a lot of flow work with a stock 2100 intake and was very impressed how much better it was than the AVS intake.
Old 08-04-2017, 02:05 PM   #354
jimi
Liked 21 Times in 8 Posts
Now you're going to have to explain just what it is that I'm tap dancing about. Aftermarket aluminum intakes on combos that didn't come with aftermarket aluminum intakes aren't stock and shouldn't be legal in Stock. That simple.
OBTW, I'm not much of a dancer.
you can dance just loosen up your laces
Old 08-04-2017, 02:08 PM   #355
jimi
Originally Posted by David Lee View Post
I am building a 67/68 cuda right now and to answer your question I bought two 340 dealer replacement blocks and have them sleeved down to a 318 bore. I plan on doing my own short block and have shane studley do my heads.
And I have heard that aftermarket blocks get a hell a lot more hp than 5.
you have a source for standard deck ht 59 degree aftermarket mopar small block blocks?
Old 08-04-2017, 03:15 PM   #356
David Lee
Liked 346 Times in 126 Posts
that is not the point, how many other combos do not have any option? Billy and other people are being myopic by only wanting to look at one or two mopar manifolds and want to ignore other combos that get an updated block, and replacement carbs.
Old 08-04-2017, 03:32 PM   #357
James Perrone
Liked 1,844 Times in 430 Posts
You can have a block. Stop crying. You are the second coming of theDROoZe
Imagine if you had the 340 combo you have a reason to babble
Go back and sleeve your block and make some magic.
If you half your energy into your 318. As you do in this thread you may get somewhere
james perrone 1290 STK
Old 08-04-2017, 03:34 PM   #358
David Lee
wow, did you actually read what i typed or did you just react?
Old 08-04-2017, 04:12 PM   #359
Hacksaw
Liked 312 Times in 175 Posts
This thread is killing me. I don't know if I should start to build a Mopar Stocker or pack drag racing in all together.
Old 08-04-2017, 11:36 PM   #360
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
That's a load of B.S. right there lol. Some of us know exactly what that LD 340 intake was worth on the exact combo in question . I'm not taking anything away from the guys who made it happen they did the homework they convinced NHRA to allow the use of this intake and went on from there and did what they needed to do to make it work ..
I Guess next is going to be how hard it is to find a
Good stock Q jet and let us bolt on Fuel injection.
Maybe even a Aluminium D port head some day .
I will let you know what the side by side comparison is on those cause it's probably Zero point Zero as well.
No assuming here lol.
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
