Liked 2 Times in 1 Post
Does everyone run there system 1 qt low for example a 4qt pan = 3qt actual amount - 5 qt pan = 4 qt actual - or is 3 quarts in the pan the number regardless of pan capacity - Thank's in advance
Liked 314 Times in 177 Posts
This sounds like a Stocker question
Liked 99 Times in 49 Posts
On the 350 chevy with a 4qt pan you can run 3 tax 2.5 if you brave, first pass keep a eye on the oil pressure in the shutdown area!
If you were able to see inside that motor at the 1000ft cone, you would change your mind. Be smart, run the OE recommended amount of oil. What you may gain simply does not compare to what you will eventually lose.
Liked 783 Times in 195 Posts
Not exactly true for GM cars. Corporate policy for many years was to design the oil pan to hold a quart more than the minimum required for maximum operation, thus the "1 qt low" mark on the dip stick was really still okay for all modes of operation. Their recommendation to keep the level up was to maintain that cushion.
Maybe other mfrs were different, but it would not make sense to design an engine with an oiling system that could nominally run below the minimum necessary to maintain engine longevity and then place a 50K to 100K mile warranty on it.
Liked 77 Times in 15 Posts
Running as little oil as possible, no, never, who would do that, why, it's just a bracket race..........
Liked 264 Times in 69 Posts
Why ruin an engine by using less oil?
John Dinkel 3295 STK |
Liked 133 Times in 76 Posts
First I install the dipstick and tubes with the engine on the stand and see where the full mark is relative to the crank. Then you can fill to where you want the oil level to be on startup. 1/8mi you can get away with a low oil level, I don't know about the 1/4mi.
Liked 22 Times in 22 Posts
I ran 5 quarts in a 7 quart pan successfully for years in the 1/8th mile with a high volume, high pressure pump, but the second run in the 1/4 mile, going through the traps at 10,600, we spun cam bearings. Is it the extra 1/8th mile? I think it was.
don,t have one |
Liked 707 Times in 284 Posts
I installed a digital dash and have a oil pressure sensor. I have a 7 quart pan and run 5 quarts. When replaying pass the oil pressure would fluctuate from 15lbs to 50lbs throughout pass. Looks scary on graph but no bearing problem in filter or on rebuild. Motor runs 6300 to 8000 rpm. The fluctuation is so fast in time and I don't think a mechanical oil pressure gauge can catch it.
