Anyone use the MT 3056 29.5x9-15 bias slick on a 10 inch rim?If so, what is the actual circumference mounted on the ten inch wheel?
Thanks
http://stevecoxracing.com |
Liked 68 Times in 26 Posts
I measured mine, it's 92 " cir. with 12 1/2 # air on 10 " rim
Just too clarify. The 3056ST is the stick version. We run them. The rollout can vary. I have had 91 1/4 to 92 1/2. They will look in the warehouse if you have a preference when ordering direct.
James Schaechter 3163 STK |
Liked 10 Times in 6 Posts
I would try Larry Hodge Racing at 217 677-2358 for M/T tires,great guy.
The last time I tried to deal with Summit or Jegs on tires,they weren't real helpful on getting me set up with what I needed. |
Liked 25 Times in 9 Posts
93 1/4" I have on mine.
Thanks everyone for the info.
Liked 20 Times in 15 Posts
Measured mine today. 94.5". Looks like it double posted.
Measured mine today. 94.5 ". 12 lbs air.
Was that a 8 inch or 10 inch wide wheel?
Thanks
That is on a 10" rim.
