Liked 346 Times in 126 Posts
I am about to start rebuilding the front suspension and steering on my 67 cuda. Re there ant preferred control arm bushings and balljoints to make the front end work better for launch?
Thanks |
Liked 584 Times in 94 Posts
If you have the budget and only want the best, contact Kim Rhoads in Pa....I don't have his number, but I'm sure someone does.
Liked 19 Times in 9 Posts
If you have the money and wish to do it right, switch it over to any A body after 1967. They are different and stronger (better engineering).
K member and related parts bolt right in. Also, as I recall, there are a few race related front control arms that are better and have better bushings. ![]() |
Liked 800 Times in 337 Posts
Yes, the idler arms after 67 are better and much easier to find.
Good luck! Bill |
any year after 67 as far as the control arms and related parts?
Liked 25 Times in 16 Posts
The 1967 idler arm has a stud on the pivot end and the K-member has one tab. I replaced the idler arm on my 1967 Dart and it seemed like it needed replaced again within a couple of years. I'm going to replace the whole K-member and suspension with disc brakes from a 1973 340 Duster with the spool engine mounts. I'd probably switch to the 1973-6 spool mount K-member. The sway bar is different as it goes through the K-member. I'm not sure if the 1968-1972 idler arm could be adapted by welding on another tab for a double shear arrangement with a thru bolt?
Mopar 2 Ya! |
Liked 23 Times in 13 Posts
P M me
Frank Bialas 1570 STK |
Liked 124 Times in 44 Posts
Has anyone replaced bushings with bearing like the Cheby guys?
Liked 53 Times in 38 Posts
Yes I have, lca with bronze bushing in a steel housing and uca with aluminum-steel bushings. Both have grease fittings. Hope they work, definately free moving. If they don't I'll re-engineer till they do. Pictures for $10,000 LOL
