If a car moves up a class to a lighter class, is there a max weight it must meet?
Random example. The 1969 Nova. 3337 shipping weight with Manual Trans and iron heads is 385hp. Weight Break 8.66 B/S. Is there a minimum weight it would have to meet to run A/S 8.00? Or can it weigh whatever and jump up to that class? Going down a class I understand adding to meet the minimum of that weight break.Does it go both ways? Thanks!!!
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster |
Liked 5,120 Times in 1,951 Posts
You can't be over B weight, and run A, if that's what you're asking.
(EDIT)So 3506 or less is good?
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster Last edited by Rat Raceway; 06-30-2017 at 01:27 AM. |
Liked 310 Times in 174 Posts
Yes, there is a max weight for class racing. If your weight is more than your class than you must move to the next lower class or get bounced. Approx. 15 years ago NHRA stopping anyone from utilizing excessive amounts of ballast. The reasoning is: get a more realistic hp factor for that combo. Comp, is different, the exact rule is lost some where in between my ears, can only be within so many inches as claimed ....... I think
Liked 332 Times in 180 Posts
Comp is pounds per cubic inch plus whatever rule book says concerning heads/ carbs/transmission etc
No. I don't know where you got that number. Please explain.
#7 | |
![]() 3337 plus 170 for the driver is 3507 Minimum weight So one pound off the B/S minimum 3506 and you are good to race up a class?
Liked 258 Times in 49 Posts
A min: 8×385=3080+170=3250
B min: 8.5×385=3272 +170=3440 All weights are rounded down to the next 5 pound increment. The A max would be less than 3440. Al Corda |
Liked 10,701 Times in 2,228 Posts
