Old 06-04-2017, 11:03 PM   #1
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Default Gm 12 bolt 430 vs 433 gears
Which of these is preferred.pro gears in a heavy car.
Chris
chris ok is offline   Reply With Quote
Old 06-05-2017, 03:44 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Gm 12 bolt 430 vs 433 gears
The one with the most teeth on the pinion would be my choice.
Pinion, That is where the failure usually starts...
Adger Smith (Former SS)
Old 06-05-2017, 10:19 AM   #3
Jeff Stout
Liked 704 Times in 281 Posts
Just took my 4.30 pro gear out. Went with 4.88 pro gear as I have been running 1/8 mile. Car is 3360 lb. w/trans brake, w/sbc and with 220 runs they are perfect and quite. I would sell them cheap if interested.
Old 06-05-2017, 11:06 AM   #4
nickh
nickh's Avatar
Liked 642 Times in 192 Posts
Jeff check your pm
Thanks
Nick
nickh is online now   Reply With Quote
Old 06-05-2017, 12:47 PM   #5
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
x2
S/ST 51
S/C 53
Old 06-05-2017, 02:01 PM   #6
chris ok
chris ok's Avatar
Looks like 430 it is
10 vs 9
Thank you Adger for info
Now to find a set
If the sale here falls thru let me know
Otherwise if someone has a new set I'd be interested right now.
Chris
Old 06-05-2017, 03:06 PM   #7
Jeff Stout
I stand corrected. I just checked mine in box and it is 4.33 ratio. 9 pinion and 39 ring gear. Car has been 9.0s with 1.32 sixty on 10 inch tire and gears look excellent
Old 06-05-2017, 03:35 PM   #8
Lenny5160
Lenny5160's Avatar
Originally Posted by Lenny5160 View Post
x2
You know what, I didn't think deeply enough when reading that. I would go with FEWEST teeth on the pinion gear. That means the teeth that are there, are thicker/stronger.
Sorry for the confusion!
S/ST 51
S/C 53
Old 06-05-2017, 07:40 PM   #9
Chevy55
Banned
Liked 179 Times in 89 Posts
Lenny, it's my thought that when you have more teeth on the pinion you'll have two teeth at the same time in contact with the ring gear for a longer period of time.
Maybe it's just me but I like the bigger pinion.
Chevy55 is offline   Reply With Quote
Old 06-10-2017, 02:12 AM   #10
Adger Smith
As the pinion gear gets more teeth on it the diameter usually increases.
That increase in size has an effect on increasing the root width and diameter of the gear teeth. You need to check it to be sure, but it is usually the case.
Ask an old Modified or Gas racer which gear set held up better.
Dana 6.50 or Dana 6.17.
6.17 had a larger diameter pinion gear.
