Liked 3 Times in 2 Posts
I've installed the Global West lower control arm bushing for the 4th gen firebird, the instructions they provide says to weld them into the control arm. Is this more of a CYA liability thing or do I need to get them welded? Would the control arm actually move on the bushing?
Liked 72 Times in 36 Posts
I installed Global West Bushings on my 67 Nova. I had to press all of the bushing in, they all fit pretty tight. I didn't think they needed to be welded. If they needed to be welded I would have only tack them in a couple of places not a full pen weld. Plus in your case they may be in certain places where Global West have found out from custormers they may have had problems and the fix was to weld the bushing in place. In my case the bushings were press fit and I was satisfied with all the parts I bought from them. Kenney Kelley
Liked 310 Times in 174 Posts
Don't think it's any kind of liability thing. Probably trying to insure that the bushing does not spin in the control arm. Three equal .500" long shots of TIG weld should suffice.
Thanks for the replies. Is there a recommended shop in the Columbus area, I am north of Columbus.
Liked 140 Times in 46 Posts
Mine fit snug but I tacked them in place just to make sure they didn't move.
Are you looking for a shop to do the work or align it after the install?
Jon Sarrett Stock 3779 |
I found a fabricator right around the corner from my place to weld it, who knew. I will eventually need a shop to align the front end.
