#41 | |
Liked 431 Times in 224 Posts
I'm not saying I necessarily agree with that, but I'm guessing that would have been the result had Jim managed to win that round. If Hidalgo had been red, it wouldn't have mattered and he would have been reinstated following the opponent's DQ.
S/ST 51 S/C 53 |
#42 | |
Liked 5,143 Times in 1,964 Posts
On the other hand, NHRA says , if you stage on it, you own it. (period) Can't have it both ways.
#43 | |
#44 | |
Agreed.. Just a lot of what if situations that could have been avoided if the tower and Jim had been paying attention. |
#45 |
Liked 312 Times in 175 Posts
May the driver be aware. period .
#46 | |
Maybe the incorrect dial is allowed by the rules and maybe it isn't. In either case, if you stage on it, you own it.
S/ST 51 S/C 53 |
#47 |
Liked 320 Times in 102 Posts
What ever happened to "First or Worst"........
When a car stages with an over the index dial in it is the "first" DQ..... End of story.....
#48 |
Liked 478 Times in 91 Posts
I think this has been brought up before, but could someone explicitly state where in the rules it says you have to dial under your index? I looked for a little bit and couldn't find it, but I very well could be missing something.
Austin Williams 3 SG 464Q STK SC |
#49 | |
I'm not sure where 'dial-in over index' would fall on the hierarchy of infractions; just pointing out that your 'end of story' statement because it is first would not be accurate.
S/ST 51 S/C 53 |
#50 | |
I think the 'Dialing Under The Index' section of Race Procedures, Section 2, Page 5 would cover it: DIALING UNDER THE INDEX Contestants in Super Stock and Stock have the option of dialing under their class’ assigned index. It is the responsibility of each contestant to place the selected time on the windshield and tower-side window prior to each round of competition. Dial-unders may be changed between rounds, including a rerun situation. All contestants not choosing to dial under will automatically be handicapped on the basis of their assigned class index. In cases where two cars of the same class are paired, the race is conducted on a heads-up basis, regardless of any dialing under considerations, and breakout rulings do not apply. So, by the rule, you can dial whatever you like but you SHOULD be automatically capped at the class index. Interesting can of worms with this run, for sure.
S/ST 51 S/C 53 Last edited by Lenny5160; 05-09-2017 at 04:45 PM. |
