Liked 5 Times in 3 Posts
I am looking at a 2000 Monaco Windsor 40' 1 slide 350 Cummins, and Allison trans. I tow a 24' enclosed will it have the power I need? any comments welcome. I now have a 2004 Georgetown V-10 and is pretty good for towing.
Thanks |
Liked 704 Times in 281 Posts
You should be happy. My 300HP American Eagle pusher pulled 28 ft trailer and only struggled up the grapevine in CA. 8MPG
Liked 3,181 Times in 972 Posts
If you liked your V10 you'll love the 350 Cummins. Just make sure there isn't any open campaigns and that maintenance has been kept up to date. On long grades you may be passed by larger DP's (450-600 Cummins are becoming more common) but will keep up with heavy trucks no problem. If not a side radiator keep your eye on temps pulling an enclosed.
Liked 9 Times in 3 Posts
my 40ft. winnebagp has a 350 cummins . no problems pulling my 30ft. tag. trailer is 12k loaded.
Mark Markow 171 ss/tb |
Thanks all!
Liked 124 Times in 44 Posts
My 275 HP Cat pulled a 26 foot trailer with a '55 Cheby to Ohio and back a couple of weeks ago. 9.7 mpg and only struggled on the LONG west bound pull into Albuquerque. Just gave it a little boost to 335 hp and increased the torque by 60 foot pounds. Really pulls the trailer better, will know after next weekends tow to Tucson if the fuel economy changes.
