Old 03-26-2017, 09:55 PM   #11
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Re: Metric 200 question
We do run a brace, and haven't had a problem in 3 years.
J.R. Haddad is offline   Reply With Quote
Old 03-28-2017, 12:06 AM   #12
Everett Vassar
Liked 2 Times in 2 Posts
What does the brace look like,and where does I t go?
Everett Vassar is offline   Reply With Quote
Old 03-28-2017, 12:27 AM   #13
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
I cracked two before going to an ultra bell.
Bob Don 128 SS
Old 03-28-2017, 06:14 AM   #14
Alan Nyhus
Liked 800 Times in 237 Posts
One version:
"That'll never work....."
Old 03-28-2017, 09:02 AM   #15
PozQB14
Liked 42 Times in 17 Posts
This is kind of off topic but still a metric question. Has anyone ever broke a rear end gear set and as a result hurt the transmission, specifically a metric 200?
PozQB14 is offline   Reply With Quote
Old 03-28-2017, 09:51 AM   #16
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Turbo Action also has a bellhousing for Metric 200. Check with them.
2894 STK
Old 03-28-2017, 10:06 AM   #17
Jim Kaekel
Liked 539 Times in 112 Posts
Common problem not only related to TH200's. Anytime you tear a ring & pinion out, it's a good idea to drop the pan on the trans at the same time. Banging from the rear end often causes roller clutch (sprag) failure.
Jim Kaekel 3836 STK
Old 03-28-2017, 10:16 AM   #18
Signman
Liked 269 Times in 99 Posts
Would think cracking the bell is caused by stress from chassis flex.
There is ET in a stiff chassis.
Old 03-28-2017, 10:43 AM   #19
PozQB14
Where/when will you notice the failure? I put new gears in the car just so I can move it. I started the car up and just went forward and reverse to put it in the garage and nothing seemed out of whack. Ill definitely drop the pan, would I feel a difference in higher gears?
Old 03-28-2017, 11:00 AM   #20
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
One version:
Who makes the brace? I done a search and couldn't find one. Thanks.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
