#11 |
Liked 1,471 Times in 308 Posts
We do run a brace, and haven't had a problem in 3 years.
#12 |
Liked 2 Times in 2 Posts
What does the brace look like,and where does I t go?
#13 |
Liked 905 Times in 193 Posts
I cracked two before going to an ultra bell.
Bob Don 128 SS |
#14 |
Liked 799 Times in 236 Posts
"That'll never work....." |
#15 |
Liked 42 Times in 17 Posts
This is kind of off topic but still a metric question. Has anyone ever broke a rear end gear set and as a result hurt the transmission, specifically a metric 200?
#16 |
Liked 60 Times in 12 Posts
Turbo Action also has a bellhousing for Metric 200. Check with them.
2894 STK |
#17 |
Liked 535 Times in 110 Posts
Common problem not only related to TH200's. Anytime you tear a ring & pinion out, it's a good idea to drop the pan on the trans at the same time. Banging from the rear end often causes roller clutch (sprag) failure.
Jim Kaekel 3836 STK |
#18 |
Liked 269 Times in 99 Posts
Would think cracking the bell is caused by stress from chassis flex.
There is ET in a stiff chassis. ![]()
#19 | |
Where/when will you notice the failure? I put new gears in the car just so I can move it. I started the car up and just went forward and reverse to put it in the garage and nothing seemed out of whack. Ill definitely drop the pan, would I feel a difference in higher gears? |
#20 |
Liked 70 Times in 31 Posts
Who makes the brace? I done a search and couldn't find one. Thanks.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
