Old 03-06-2017, 02:48 PM   #11
David Lee
Liked 346 Times in 126 Posts
Default Re: HP Reduction Request
Anything to reduce cost and bring new blood into class racing, I welcome, what can i do to help this ball rolling forward
Old 03-06-2017, 03:12 PM   #12
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
The quota is full with 4 grade points. They want less stockers not more. Top dragster is much more fan appealing. Just watch the stands empty when they call Stock.
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 03-06-2017, 03:17 PM   #13
Ed Wright
Ed Wright's Avatar
Doesn't fall within the guidelines of this thread.
Let's try to keep this thread .."on topic"
Bless your heart.
Ed Wright 4156 SS/JA
Old 03-06-2017, 04:19 PM   #14
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Originally Posted by Nmbr1GMfan View Post
Question, who are these new racers? New to the sport or attracted from the bracket side or elsewhere?
Me, for 1
Dave Noll, EF/S ,?/SA 6526
Old 03-06-2017, 04:59 PM   #15
Talking Re: HP Reduction Request
Daran, There are more independent S/SS events all the time . They still use the NHRA specs and horsepowers.
The guys are still going to be members and comp numbers users, in most cases.
That is, unless they don't care about memberships anymore either.
Are they relishing in de-evolution then? Who knows?
Maybe Devo was right. LOL
Old 03-06-2017, 05:00 PM   #16
Nmbr1GMfan
Probably a combination of all those areas and more. It would be hard to gauge how many people are in the shadows and would participate if it were made easier and less expensive.
Honestly, from the perspective of someone on the outside looking in, Most current racers in the bracket classes don't understand class racing AT ALL. I was surprised when I asked questions about S/SS how many racers couldn't tell me the first thing about them. Now the people that do run the class, well they aren't talking either because they aren't giving away any secrets. Case in point, I have a 2005 GTO I could run as an 04 and probably be moderately competitive, now there isn't many of these out there but first on the agenda would be a solid axle swap, when I contacted people involved with the current cars in the class I got vague answers and a "no pictures" reply. Now I get it for sure, but it sure makes me think a S/G car might be looking good at this point. Also... and this is a big one, completely take away the cost of the car and look at the cost to get there, race, then get home plus the time off work, let alone the countless hours to hone the combo, I can easily see how these classes would be unobtainable to most.
Old 03-06-2017, 05:03 PM   #17
Nmbr1GMfan
Originally Posted by Dave Noll View Post
Me, for 1
Did you come from another class Dave or did you jump right in the stock pool?
Old 03-06-2017, 05:14 PM   #18
GUMP
Liked 2,362 Times in 559 Posts
I have a few photos that I will gladly share. PM me an email address.
Old 03-06-2017, 05:23 PM   #19
Nmbr1GMfan
Done. Thanks so much.
Old 03-06-2017, 05:57 PM   #20
oldskool
oldskool's Avatar
Liked 748 Times in 363 Posts
This sounds like a great idea to me.
I've wondered why a lot of 2-barrel BOP engines are not raced. When I look up the specs, it appears that some of these 2-barrel engines are only rated maybe 40hp less than a very similar engine which can use an 800cfm Q-jet.
So, that brings up a question which should be in line with this thread. For most GM carb engines, 350 cubes & bigger, aprox how much less power is possible when only a 2-barrel is allowed ?
It appears to me that a 2-barrel would be the limiting factor, whereas an 800 Q-jet would not pose a limit at all, since there are lots of 9 & 10 sec cars, using 750 & 800 Q-jets.
So, considering this, what would be a good number to begin with, for most GM BOP 2-bl engines, that are not being raced ? Or, to put it another way, how much less should the initial factor be, as compared to a very similar 4-barrel engine ?
Since I'm a Pontiac guy, I'll just use a '76 Pontiac 350 as an example. I just looked it up on the Class Racer Info site. The 2-barrel version is factored at 220hp. The 4-barrel version is factored at 260hp. I've seen the 4-bl version in a competitive car. Have never seen the 2-bl version. So, aprox how low would the factor have to be, to make the 2-bl version competitive, or at least run a safe amount under the index ? I'm assuming a properly built & tuned car.
http://www.classracerinfo.com/Engine...3&MAKE=Pontiac
http://www.classracerinfo.com/Engine...4&MAKE=Pontiac
If this post is out of order for this thread, please delete it.
Thanks !
