View Poll Results: Fuel injection? Do you run in open loop or closed loop
Open Loop 80 65.04%
Closed Loop 43 34.96%
Voters: 123. You may not vote on this poll
Old 04-05-2016, 06:26 PM   #71
jimmyparker
Liked 309 Times in 88 Posts
Default Re: Fuel injection? Open or Closed loop?
Thanks Ed, I think I know enough now to be dangerous.
Jimmy
jimmyparker is offline   Reply With Quote
Old 04-06-2016, 09:43 AM   #72
Ed Wright
Ed Wright's Avatar
Jimmy
Who's ECU are you using?
Ed Wright 4156 SS/JA
Old 04-06-2016, 04:30 PM   #73
jimmyparker
Ed, it's a FAST XL1. Matt Maxwell with FAST did some upgrades on it this past weekend in Atlanta.
Jimmy
Old 04-06-2016, 04:39 PM   #74
Ed Wright
Ed Wright's Avatar
Great system. you should be good.
Old 02-04-2017, 01:49 AM   #75
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Sounds like you should be a lot more consistent in open loop. So do you do a couple of TT's or qualifying runs in closed loop for learning and then go to open loop for elims. to get the consistency?
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 02-04-2017, 09:49 AM   #76
Ed Wright
Ed Wright's Avatar
That was 2012, learned what I was doing wrong. I've run it both ways now. If you have it tuned correctly, it makes almost no corrections in closed loop anyway. Makes no difference I can see now.
Old 02-04-2017, 02:39 PM   #77
Darrel Goheen
So do you normally run closed loop now? I know it's an old thread. I was just going through old posts trying to learn. Thanks.
Old 02-04-2017, 03:04 PM   #78
Ed Wright
Ed Wright's Avatar
Closed Loop. O2 sensors don't live long with leaded fuel. I replace mine at the start of each season. Runs the same both ways. Once the tuning is right, it makes no difference. Hit some strange weather conditions, may help.
Old 02-04-2017, 04:07 PM   #79
Darrel Goheen
I did buy an extra Bosch sensor. Do you use Bosch sensors or NTK. Maybe NTK isn't an option with FAST. Holley offers a NTK for double the price but is suppose to last longer with leaded fuel.
Old 02-05-2017, 12:05 AM   #80
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
My Holley Bosch sensor lasted thru 2 dyno sessions and driving the car in and out of the shop then the car fell on its face while testing. The logs showed strange readings and I already had a NTK with me at the track. I switched to the NTK and it was back to normal. This is with C-16. I was wondering about how often the NTK should be replaced as well.
Sean
Sean Marconette
84 Mustang
5060 SS/N
