Old 02-02-2017, 10:06 PM   #31
GTS340
Liked 1,354 Times in 413 Posts
Default Re: Important if you run D-H/S or SA
Thank you Mark!
Old 02-02-2017, 10:26 PM   #32
House of Darts
Liked 20 Times in 15 Posts
How far do you think Pandora's box has been opened? I started out with a blueprinted 440+6 with a 7" slick in 1972. I guess you'll need to go back to the NHRA constitution and read about the founding fathers too. Stock? Yeah! Right! Billy I really respect you but if you want to fight about something how about we all go back 40-50 years. Stock Eliminator at its best!
House of Darts is offline   Reply With Quote
Old 02-02-2017, 11:23 PM   #33
Dennis P Chapman
Liked 53 Times in 25 Posts
Originally Posted by ed fernandez View Post
you think people are pissed at trump. I'd love to see nhra make billy head of tech.
Yeeeeeeee haw.
x2
Dennis P Chapman 1904 STK
Old 02-03-2017, 07:59 AM   #34
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Carter AVS is also spread bore.
A Carter AVS is not a spread bore, I have run this combo in my 68 Cuda since 1978. For a thermoquad to work without a spacer you would have to machine this manifold. Also my car will still fit in G with this combo. Before you worry to much about this combo, which there aren't that many out there, you might want to take a look at the 91 Corvette which holds the G/SA record at 10.54 at 124 or the 73 Pontiac TA - 455 at 306 hp. If you think all this aluminum stuff helps so much (other than weight) then why is the 70 Duster with aluminum heads 2 hp less than with cast iron heads? The AVS 340 combo & the 383 only take a 1 hp hit with aluminum heads & be prepared to spend big $$$$ to make them legal. Wish I could use a Quick fuel carb or a 4 speed auto trans. Didn't powerglide combo's got a 3 speed, why can't I run a 4 speed auto? That would help way more than a manifold. Can someone tell me, what is stock about stock eliminator these days. Just sayin.
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 02-03-2017, 08:34 AM   #35
goinbroke2
Liked 405 Times in 158 Posts
Having a hard time finding those 4bbl intakes that were an over the counter option on 72-82 302's, should just let them run with a performer as well along with the 600cfm holley. Of course the hp will have to be lowered to 100-105hp to make it "fair".
(75 mustang at 2000# to fit U/SA?? that aught to set some records lol)
Old 02-03-2017, 09:40 AM   #36
James Perrone
Liked 1,861 Times in 434 Posts
Originally Posted by Chuck Beach View Post
A Carter AVS is not a spread bore, I have run this combo in my 68 Cuda since 1978. For a thermoquad to work without a spacer you would have to machine this manifold. Also my car will still fit in G with this combo. Before you worry to much about this combo, which there aren't that many out there, you might want to take a look at the 91 Corvette which holds the G/SA record at 10.54 at 124 or the 73 Pontiac TA - 455 at 306 hp. If you think all this aluminum stuff helps so much (other than weight) then why is the 70 Duster with aluminum heads 2 hp less than with cast iron heads? The AVS 340 combo & the 383 only take a 1 hp hit with aluminum heads & be prepared to spend big $$$$ to make them legal. Wish I could use a Quick fuel carb or a 4 speed auto trans. Didn't powerglide combo's got a 3 speed, why can't I run a 4 speed auto? That help way more than a manifold. Just sayin.
Chuck you need a 4speed I will by the 3 rd pedal for you ! G/S looks better on your window
james perrone 1290 STK
James Perrone is online now   Reply With Quote
Old 02-03-2017, 10:05 AM   #37
Chuck Beach
James, how you doing? My car was an original 4 speed, it would be cool, thanks.
Chuck Beach
3340 STK
Old 02-03-2017, 11:26 AM   #38
GTS340
One thought on this also. First hi Chuck I wrote in a bad why and your right there are maybe 5-8 cars this effects. In 1970 Chrysler sold this intake as a replacement. They didn't sell aluminum heads. Stock didn't come with roller rockers and the list goes on. But this intake was.
Also Chuck I should know better. Earl Blake's car is in my garage and the 68 Barracuda surely still runs 'G". Sorry to forget you on that. Actually not sure "D" is in trouble either. Trying to get my Dart down to 3010 lbs with me in it and still work might be difficult.
Old 02-03-2017, 01:57 PM   #39
jimi
Liked 21 Times in 8 Posts
what makes anyone think that the edelbrock intake is worth hp? the factory cast iron intake is a pretty good piece.
Old 02-03-2017, 01:59 PM   #40
Chuck Beach
Bingo - we have a winner!!!
Chuck Beach
3340 STK
