Old 01-07-2017, 06:54 PM   #1
Greg West
Liked 52 Times in 22 Posts
Default Clutch Fork/Bellhousing Interference
I have a 6022W Quick Time bellhousing, McLeod SoftLok clutch assembly, 16505 McLeod throwout bearing, and a 3887177 GM clutch fork. When I adjust the clutch ball so there is clearance between the pressure plate and the clutch fork, the clutch fork hits the engine side of the transmission face plate on the bellhousing before the pressure plate releases the clutch disc. Has anyone else run into this problem?
Thank you.
Greg West is offline   Reply With Quote
Old 01-07-2017, 07:15 PM   #2
Chevy55
Banned
Liked 179 Times in 89 Posts
Default Re: Clutch Fork/Bellhousing Interference
I had that problem but when I changed to a motor plate it moved the trans back to give me the clearance. Maybe you could add another block plate to move the tranny back?
Chevy55 is offline   Reply With Quote
Old 01-07-2017, 07:26 PM   #3
Greg Barsamian
Liked 427 Times in 97 Posts
Are you using Lakewood Clutch Linkage? (Lakewood Part # 2478)
Old 01-07-2017, 07:42 PM   #4
Greg West
I have modified the pivot ball I have so I can adjust it in and out. With the pivot ball that came with the Quick Time, the fork is up tight against the pressure plate. I did compare the distance from the engine face to the trans face of the Quick Time bellhousing and an old Lakewood housing that I have. The Quick Time is .068" shorter than the Lakewood. This measurement includes the difference in thickness of the respective engine plates for each bellhousing.
Old 01-07-2017, 07:56 PM   #5
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
I got rid of the ball altogether and bought a Browell fork with a heim joint. Very adjustable both for depth and in and out.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 01-07-2017, 08:07 PM   #6
Bob Gullett
Bob Gullett's Avatar
Liked 507 Times in 116 Posts
What kind of clutch are you using? I used to run the QT 6022W with a stock fork, stock non adjustable fork pivot ball with a 16010 McLeod bearing and dual disc 7in clutch. Never had an issue with a fork hitting the pressure plate.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 01-07-2017, 09:14 PM   #7
Greg West
Thanks for the replies. The clutch is a McLeod Soft Lok with a .380" thick disc. If I shorten the pivot ball so the fork doesn't hit the pressure plate, the fork will then hit the bellhousing when the clutch pedal is depressed preventing the clutch from disengaging.
Old 01-07-2017, 10:39 PM   #8
Bob Gullett
I use the GM fork 3892632 not the Corvette style. Not sure if that makes a difference or not.
68 Chevy11 327 F/S
Old 01-07-2017, 11:49 PM   #9
james schaechter
Liked 1,436 Times in 299 Posts
The throwoutbearing has spacers that you may have to take out To make it short enough. With a .380 disc it is pretty tight in there. Is it also shimmed between the flywheel and pp? You might have to put the QT spacer between the bell and block saver. I think the part number is rm-198. It is .250 thick. You would have to run a long pivot ball and check your crossmember and driveshaft fitment, but it opens up a lot more room for you.
James Schaechter 3163 STK
Old 01-08-2017, 12:14 AM   #10
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Like Ed, I went with the Browell fork and heim pivot. Best thing since sliced bread. Browell also has a variety of throwout bearing collar lengths available that might help.
T Ames is offline   Reply With Quote
