Old 12-06-2016, 09:24 PM   #11
Liked 5,124 Times in 1,953 Posts
Default Re: What if NHRA granted you a 20% reduction on h.p. on any
60 Starliner, 352/360/288!
Now allowed a 4 speed.
.500 lift solid lifter cam...Oh wait a minute here ??
Old 12-06-2016, 09:35 PM   #12
Heck of a reduction. Why would anything get a 20% reduction?
Question is...Why did?
426 Street Wedge, 365/291
That's 20-21
Old 12-06-2016, 09:40 PM   #13
Sam Murray
Sam Murray's Avatar
Liked 60 Times in 29 Posts
1966 Olds 442 tri power
Sam Murray
1616 STK
Sam Murray is offline   Reply With Quote
Old 12-06-2016, 10:28 PM   #14
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
[QUOTE=Mark Yacavone;521696]Question is...Why did?
That's 20-21[/QUOTE
It uses the same heads, cam and 565 CFM carb as the early 383 which was unusable until it was defactored to 280 HP. The only advantage the 426 has over the 383 is it can fit a little more duration, with identical cams both engines would make almost identical HP. I did this test in my Sport Fury back in 73 to prove a point to some friends. I had been running a 426 street wedge I built using a 413 .070 block because the original block was cracked. It had a stock 63 Max cam, stock 915 heads a TM7 mani and a 4779 Holley with a stock Road Runner 11" convertor, it typically ran 12.50s with an occasional high 40 at 110-111. I had pulled the engine to upgrade it and still had to race every weekend in the brackets so I took an 80K mile 383 short block that came out of a friends car and put in the same cam, heads and carb with a Torker mani I borrowed. The first day out it ran 12.50s at 110 as it smoked down the track, it also had about a half of a point less compression than the 426, my friends were shocked, I wasn't, I still have all of the time slips dating back to 71.
Old 12-06-2016, 10:35 PM   #15
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: What if NHRA granted you a 20% reduction on h.p. on any
61 bubbletop with a 348/250. 250 minus 20%? 200 HP, yeah that would fly and look coooool.
4 speed, Powerglide or 3 speed? Also,what class would that fit? Yes,it would be neat.
Old 12-06-2016, 10:37 PM   #16
Paul Precht
A 62 Plymouth 318 4 barrel.
Old 12-06-2016, 11:25 PM   #17
GarysZ24
GarysZ24's Avatar
Liked 238 Times in 94 Posts
Talking Re: What if NHRA granted you a 20% reduction on h.p. on any
Originally Posted by Mike Graham View Post
Ford 302 1975
R.O.L.O.L......Nice try Mike, Nice try!!!!
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
Old 12-07-2016, 01:10 AM   #18
Pinballer
Pinballer's Avatar
Liked 13 Times in 7 Posts
I'd be ditching the AMX and finding a '71 Opel GT. 20% off 75 HP looks pretty good to me!
Brian Saunders Lerna IL
'79 AMX T/SA 3790 currently being resurrected
Pinballer is offline   Reply With Quote
Old 12-07-2016, 02:18 AM   #19
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
My old 1988 Cadillac Cimarron, 2.8 - 125/155. - 20% = 124hp.
Oh yeah! Jim
Old 12-07-2016, 07:19 AM   #20
Alan Nyhus
Liked 799 Times in 236 Posts
'68 Pontiac 250" OHC 6 cylinder, currently @ 215 hp.
"That'll never work....."
