#11 |
Liked 5,138 Times in 1,961 Posts
60 Starliner, 352/360/288!
Now allowed a 4 speed. .500 lift solid lifter cam...Oh wait a minute here ??
#12 |
Question is...Why did?
426 Street Wedge, 365/291 That's 20-21
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 12-06-2016 at 09:41 PM. |
#13 |
Liked 60 Times in 29 Posts
1966 Olds 442 tri power
Sam Murray 1616 STK |
#14 |
Liked 327 Times in 121 Posts
[QUOTE=Mark Yacavone;521696]Question is...Why did?
426 Street Wedge, 365/291 That's 20-21[/QUOTE It uses the same heads, cam and 565 CFM carb as the early 383 which was unusable until it was defactored to 280 HP. The only advantage the 426 has over the 383 is it can fit a little more duration, with identical cams both engines would make almost identical HP. I did this test in my Sport Fury back in 73 to prove a point to some friends. I had been running a 426 street wedge I built using a 413 .070 block because the original block was cracked. It had a stock 63 Max cam, stock 915 heads a TM7 mani and a 4779 Holley with a stock Road Runner 11" convertor, it typically ran 12.50s with an occasional high 40 at 110-111. I had pulled the engine to upgrade it and still had to race every weekend in the brackets so I took an 80K mile 383 short block that came out of a friends car and put in the same cam, heads and carb with a Torker mani I borrowed. The first day out it ran 12.50s at 110 as it smoked down the track, it also had about a half of a point less compression than the 426, my friends were shocked, I wasn't, I still have all of the time slips dating back to 71. |
#15 |
Liked 719 Times in 220 Posts
#16 |
A 62 Plymouth 318 4 barrel.
#17 |
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) |
#18 |
Liked 13 Times in 7 Posts
I'd be ditching the AMX and finding a '71 Opel GT. 20% off 75 HP looks pretty good to me!
Brian Saunders Lerna IL '79 AMX T/SA 3790 currently being resurrected |
#19 |
My old 1988 Cadillac Cimarron, 2.8 - 125/155. - 20% = 124hp.
Oh yeah! Jim .
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
#20 |
Liked 799 Times in 236 Posts
'68 Pontiac 250" OHC 6 cylinder, currently @ 215 hp.
"That'll never work....." |
