Old 11-28-2016, 08:27 AM   #41
Billy Nees
Liked 7,733 Times in 1,739 Posts
Default Re: Mopar 273-4bbl Combo
Originally Posted by gmonde View Post
did that ld4b edelbrock come from the factory ?? thought it was a cast iron intake
It was and it should be gone.
Billy Nees 1188 STK, SS
Old 11-28-2016, 09:37 AM   #42
Billy Nees
Originally Posted by David Lee View Post
I think this got approved because of the d-dart, but I could be wrong
D-Darts had factory modified (intake openings bored out to accept Holley) standard 273 intakes. AND adapter plates.
Old 11-30-2016, 07:10 PM   #43
65signet
Liked 48 Times in 22 Posts
I have found the early 64-66 blocks are better, i have a 65 block in my car, with some fill, all good so far, and i am just using the hooker headers for now, until i have Performance Welding build me a set someday.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 11-30-2016, 07:27 PM   #44
David Lee
Liked 346 Times in 126 Posts
what size headers are you using?
Old 12-01-2016, 12:12 AM   #45
SSDiv6
Liked 1,583 Times in 582 Posts
The D-Dart intake manifold, P/N 2536771, is identical to the 318 marine engine intake.
It's a single plane cast iron intake with an adapter for the Holley carburetor.
Name:	D Dart 1.jpg
ID:	37766   Click image for larger version
Name:	D Dart 2.jpg
ID:	37767   Click image for larger version
Name:	D Dart 3.jpg
Name:	D Dart 4.jpg
Old 12-01-2016, 01:06 AM   #46
older racer
Liked 68 Times in 26 Posts
hi, just curious, I seen marine intake for 318, casting number is2846707. the carb flange is angled quite a bit from level, thanks
older racer is offline   Reply With Quote
Old 12-01-2016, 01:26 AM   #47
Coleydog
Liked 53 Times in 38 Posts
The ones I've seen had angled spacers under carb, dad had two 400s with them. First boat had a ford 351 engine, angled spacer under carb.
Old 12-01-2016, 08:24 AM   #48
Billy Nees
771 is also listed as 66 California.
Old 12-01-2016, 02:41 PM   #49
SSDiv6
The LD4B Edelbrock intake was approved as a replacement for the 273 due to the fact it was available with a Chrysler part number. The same rationale used on the 440 Chrysler 6-Pack engine with the Edelbrock intake. The 6-Pack intake was available in both aluminum and cast iron.
Old 12-01-2016, 03:47 PM   #50
Coleydog
Looks like it would flow better than that boat anchor.
