Liked 26 Times in 10 Posts
My nephew has a 1969 Roadrunner 4 speed 383 that he want's to run in Stock Eliminator it has the lift off 6 Pack hood on it now can he keep that on a 383 car even though it was only available on the 1969 440 6 Pack combination - Thank's Bob
Liked 79 Times in 22 Posts
No, the trim package (hood, spoilers, etc....) must match the engine HP combination claimed.
For example, a 1969 Camaro was available with a cowl type hood only with some engine combinations. If you run a 350 cid, 2 bbl. engine in a 1969 Camaro, you can't run the cowl induction hood. |
Liked 2 Times in 1 Post
It's like Greenlight said. You can't run the 6pack hood with the 383. I currently run the only 383 1969 Roadrunner in NHRA Stock Eliminator in the country. Tough combination. Good luck and have fun. Derek
Derek Hake 4459 H/SA 69' Roadrunner |
Sorry I am confused if that is true how does an AAR Cuda run a Big Block (Not Available only 340 6 Pack) and compete in A/SA with a 440 I guess I have been racing in the Super Classes to long please explain for me Thank's and excuse my ignorance - Bob
#5 | |
Not sure what type of differances there are between 69 & 1970 383 MoPar engines, but Will Kellys 70 383 Cuda runs pretty well in Div. 6.
Liked 242 Times in 81 Posts
Larry Hills Cuda A/SA runs the AAR hood. NHRA allowed that back in the day and even gave the Cuda a best engineered or appearing award. The TA hood has been allowed on Challengers since the days of Paul Rossi SS/FA 440 6 pack. The story was the factory had a shortage of shakers and put the TA hood on some of them.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. Last edited by Rod Greene; 10-30-2016 at 09:27 PM. |
#7 | |
Liked 286 Times in 146 Posts
The T/A scooped hood was an available option on the '70 Challenger. Option code N94. It was available on the 340, 383, 440, and 426 Hemi. The Shaker shortage story arrived from the temporary period where the Shaker production was halted because of the lack of crumple zones in the hood. Crash tests showed the hood would come off and go through the windshield. The known N94 optioned car production dates are nowhere near the Shaker non-production period. Here's a link to a factory option book showing the T/A Hood availability on other engines: http://www.hamtramck-historical.com/...1970/page3.jpg |
I am glad that NHRA accepts both these hoods but your brochure also states shaker available for 440 4bbl and would be painted black on all but red cars. Obviously some erroneous information.
Ok I have done some more research and have seen fender tag pics of non Ta Challengers with N94 hoods.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. Last edited by Rod Greene; 10-31-2016 at 02:28 PM. Reason: more info |
Liked 58 Times in 16 Posts
That hood may have been "available" but NEVER built that way. Kinda like a 340 6 pack was "available" in 1971 BUT NEVER EVER Built! Larry's hood is a bogus deal. So is the fiberglass hood on anything BUT a 340 6pack. AND the reason for the shaker replacement wasnt "crumplezones" It was because they filled up with water when it rained. Dealers swapped them off under warranty! NEVER did Mother mopar put the fiberglass on anything else. Its like saying a Mr Norms 340 6pack in a dart is legal! I think since all the camaros gotta run flat hoods Larry and the others should have Steel on theirs! But Hey Put the Lift off on your car and cite Larry as the example! They gotta let you have it, Right????
Overkill is Under-rated |
Liked 590 Times in 213 Posts
I don't know how this thread got from a 1969 Roadrunner hood to a 1970 Cuda hood, but the answer to the original question is....no, you can not use a 6bbl hood on a 383 car. You could use the scoop hood in Super stock GT with the 383. BTW, my 69 Roadrunner was an original 383, I bought it new when I got out of the Army and still have it.
Gary Hansen - SS/FA 4911, B/SA 4911 |
