Old 08-17-2016, 06:46 PM   #1
Greg Reimer 7376
Liked 714 Times in 220 Posts
Cool Carburetor I.D.#?
Found a large Rochester 2 barrel carburetor in my stash while cleaning up today. I.D.# is 7040426. What did this once live on? It's not in the engine specs in the tech bulletin from NHRA. It's complete. I don't remember where I got it.
Old 08-17-2016, 07:16 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Carburetor I.D.#?
1970 Camaro 350 V-8 engine -Auto Trans- California
Old 08-17-2016, 07:45 PM   #3
Greg Reimer 7376
Cool Re: Carburetor I.D.#?
In about 1980, I had a 70 Chevelle 250 horse 350. It got a quadrajet and an intake change at some point while I had it. That's probably where it came from.
Old 08-17-2016, 08:29 PM   #4
Greg Reimer 7376
Thanks for the info. The Class Racer family comes through again!
Old 08-17-2016, 08:40 PM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Measure the venturi and see if it is one of the infamous 1.375" carbs. You could have a semiprecious treasure.
Old 08-17-2016, 11:18 PM   #6
Greg Reimer 7376
Kind of amazing that the 396/265 horse carb is smaller than the 350/250 carb. My 70 Chevelle as I remember had quite a bit of torque and was kind of fun to drive. It was rather fast for a car with only a 2 barrel.
Old 08-18-2016, 11:18 AM   #7
Greg Reimer 7376
Took it apart this morning. Venturi size was a 1.250. Main jets were 62's. A scan of the NHRA tech bulletin showed that the 1970 carb #7040113/114 has the 1.375"venturi.
Interestingly enough, the 265 horse 400 had a 1.250"venturi. Seems more is sometimes less.
Old 08-18-2016, 11:32 AM   #8
"California" could be the reason for the smaller venturi.
Old 08-18-2016, 12:05 PM   #9
Greg Reimer 7376
Might also be the reason for the fact that that carb number isn't on the NHRA tech sheet. Certainly there is no reason to use it anyway.
