#11 |
Liked 320 Times in 102 Posts
If you think you have a problem just measure from the area that the front pinion bearing mounts to the end of the spline.....
Measure the bearing mount diameters of the front and rear pinion bearing.. Does the companion flange fit the new gear set??????????? Just looking at the pix it just appears that difference is the length of the gear teeth on the pinion caused by a ratio change..... Just my 2 cents.... Bob
#12 | |
Liked 56 Times in 31 Posts
I spent quality time with mine, doing my first ever ring and pinion swap from scratch, and I recognize that in an instant. I have no idea what the one on the left is.
Thomas NHRA 1959 D/SA |
#13 |
Liked 33 Times in 16 Posts
He stated the new gear was on the right...maybe he has a S60 housing???
Rich Taylor I/SA - 321 |
#14 |
Liked 705 Times in 219 Posts
That gear on the left has a smaller rear pinion bearing, it probably is a truck gearset. The 12 bolt truck had a diamond shape cover and a smaller bearing. Looks like the wrong part to me.
#15 |
Weary of guessing without a part number.
#16 | |
At this point, I would be looking for any numbers on the housing and the original gear set. Is this in the '69 Camaro in your sig? Have you contacted Strange?
#17 |
Liked 308 Times in 103 Posts
If it is truck gear rear pinion bearing( next to teeth) is about .125'' smaller and bearing sets about .080'' closer to teeth(pinion is deeper in housing).
Mike Taylor 3601 |
#18 |
Liked 165 Times in 51 Posts
NEW RICHMOND NUMBER IS 79-0029-1
The gear that came with the housing ( the one without the bearing) is a US GEAR 4.88 Set up and installed by Strange Eng. I have 5 other sets of 12 bolt gears and all of them look the same as the Richmond. None of them will pass through the bearing in the housing.
Glen DeMenge 1969 Camaro Stock Eliminator |
#19 |
Have you tried looking up the numbers on the US Gear on their website to see which gear set it is?
#20 |
I think i got it, we had to polish the pinion now it seems to be working.
Please excuse my ignorance Thanks for all the replies!!
