Old 08-07-2016, 01:11 PM   #11
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: STRANGE 12 bolt housing VS GEARS
If you think you have a problem just measure from the area that the front pinion bearing mounts to the end of the spline.....
Measure the bearing mount diameters of the front and rear pinion bearing..
Does the companion flange fit the new gear set???????????
Just looking at the pix it just appears that difference is the length of the gear teeth on the pinion caused by a ratio change.....
Just my 2 cents....
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 08-07-2016, 02:25 PM   #12
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
Originally Posted by MEXJOE View Post
After looking at it I see the pinion will not pass through the bearing in the case.
new one has the bearing on it.
The one on the right is a 12-Bolt Pinion gear.
I spent quality time with mine, doing my first ever ring and pinion swap from scratch, and I recognize that in an instant.
I have no idea what the one on the left is.
Thomas
NHRA 1959 D/SA
Cdncarnut is offline   Reply With Quote
Old 08-07-2016, 02:37 PM   #13
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
He stated the new gear was on the right...maybe he has a S60 housing???
Rich Taylor
I/SA - 321
Old 08-07-2016, 02:50 PM   #14
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: STRANGE 12 bolt housing VS GEARS
That gear on the left has a smaller rear pinion bearing, it probably is a truck gearset. The 12 bolt truck had a diamond shape cover and a smaller bearing. Looks like the wrong part to me.
Old 08-07-2016, 03:02 PM   #15
HandOverFist
Weary of guessing without a part number.
Rich Taylor
I/SA - 321
Old 08-07-2016, 05:33 PM   #16
Cdncarnut
Cdncarnut's Avatar
I missed that part.
At this point, I would be looking for any numbers on the housing and the original gear set.
Is this in the '69 Camaro in your sig?
Have you contacted Strange?
Thomas
NHRA 1959 D/SA
Old 08-08-2016, 09:15 AM   #17
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 306 Times in 103 Posts
If it is truck gear rear pinion bearing( next to teeth) is about .125'' smaller and bearing sets about .080'' closer to teeth(pinion is deeper in housing).
Mike Taylor 3601
Old 08-08-2016, 11:15 AM   #18
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
NEW RICHMOND NUMBER IS 79-0029-1
The gear that came with the housing ( the one without the bearing) is a US GEAR 4.88 Set up and installed by Strange Eng.
I have 5 other sets of 12 bolt gears and all of them look the same as the Richmond.
None of them will pass through the bearing in the housing.
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 08-08-2016, 12:18 PM   #19
Cdncarnut
Cdncarnut's Avatar
Have you tried looking up the numbers on the US Gear on their website to see which gear set it is?
Thomas
NHRA 1959 D/SA
Old 08-08-2016, 12:29 PM   #20
MEXJOE
MEXJOE's Avatar
Red face Re: STRANGE 12 bolt housing VS GEARS
I think i got it, we had to polish the pinion now it seems to be working.
Please excuse my ignorance
Thanks for all the replies!!
Glen DeMenge
