Old 08-06-2016, 03:33 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Default STRANGE 12 bolt housing VS GEARS
I have a new 12 bolt housing from STRANGE.
I was going to change the gears and I have a set of RICHMOND gears.
The pinion gear on the new RICHMOND is 3/16 shorter than the gear we took out of the car.
The new gear will not fit.
Any idea what gives here.
I thought all series 4, 12 bolt, gears were the same?
Thanks!
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 08-06-2016, 03:42 PM   #2
Liked 1,912 Times in 429 Posts
Default Re: STRANGE 12 bolt housing VS GEARS
The pinion gear is 3/16" shorter where?
Which ratio?
Are both gear sets Richmond?
The same series?
Old 08-06-2016, 03:50 PM   #3
Alan Nyhus
Liked 799 Times in 236 Posts
I've never seen any 12 bolt gears where the pinion was shorter in depth, which is what I take it you're referring to?
Post a pic of the new and old pinion side by side.
"That'll never work....."
Old 08-06-2016, 05:12 PM   #4
kansas stocker
Liked 249 Times in 48 Posts
does the ring gear work?
i'm betting you have got a set for something other than a 12 bolt.
pete
kansas stocker is offline   Reply With Quote
Old 08-06-2016, 05:18 PM   #5
FED 387
Liked 334 Times in 181 Posts
could it be a BOP gear set???
Old 08-06-2016, 06:27 PM   #6
Lee Valentine
Liked 319 Times in 68 Posts
Have a strange 12 bolt in our stocker,never any problems with any brand gears, you probably have wrong gears.12 bolt truck or BOP stuff.
Lee Valentine 1661 STK
Old 08-06-2016, 06:35 PM   #7
FED 387
Richmond gear set got any numbers on it ?????
Old 08-07-2016, 11:49 AM   #8
MEXJOE
MEXJOE's Avatar
After looking at it I see the pinion will not pass through the bearing in the case.
new one has the bearing on it.
Glen DeMenge
Old 08-07-2016, 12:40 PM   #9
Woodfin
Liked 288 Times in 109 Posts
it appears that you simply have the wrong gear set. Maybe boxed wrong or looked up wrong number.
Old 08-07-2016, 01:00 PM   #10
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
If we had the number it could easily be solved...we can see the packaging in your image.
Is this it? https://www.summitracing.com/parts/r...27-1/overview/
Rich Taylor
I/SA - 321
