Liked 708 Times in 285 Posts
This is on a Harley. I ported a set of heads ( getting ready for stock eliminator LOL). Replaced the valve guides and reamed to .002 to .003 stem clearance. Using old valves and cut face to 45 degree with a 30 degree under cut. Went to head with a kwik way and cut seat to 33-45-65 degree. Lapped valve and checked with flashlight through port and can see light past seat and valve face. Without valve spring and just the weight of valve. After about 4 attempts I no longer see light passing through. I faced new stones a couple times to make sure they were correct. Valve isn't bent. I don't have a way to check seat to guide but guides have a lip and bottom out in head properly I believe. I guess my question is do you need to lap along time to get a 100% seal around seat and valve face? I know its not a class motor but you guys give good honest help. Thanks Jeff
Liked 7,896 Times in 1,754 Posts
I know that I'll probably catch a bunch of crap for saying this but "valve seal is overrated!"
Liked 30 Times in 17 Posts
Jeff,
Harleys have very short valve guides and they never go in exactly concentric to the previous guide or the seat. You always have to recut the seat. Have you checked your pilot to see if maybe it isn't bent a little ? Put it in the guide and touch the seat. Then put some dykem on the seat, turn the pilot 180 degrees and touch the seat again. It should touch right up. If it doesn't your pilot could be bent. You can do the same thing to check your valve grinder. Chuck a valve up and grind it, then turn it 180 degrees in the chuck and grind it again. It should touch right up. I always lightly lap valves just to make sure they are hitting the seat all the way around. I use 320 grit lapping compound. If the seat and guide are concentric and your pilot isn't bent or flexing, you should be able to lap the valve in and see a pattern with very little pressure.
Bill Koustenis |
Liked 22 Times in 14 Posts
#5 | |
I went and did the exhaust valve yesterday and only took 2 times to get no light to shine through. Im going to do the other head and watch carefully how seat grinder is contacting seat with some bluing. Thanks for advice. Jeff |
#6 | |
Liked 373 Times in 129 Posts
Liked 319 Times in 108 Posts
When lap valve if valve is good will have ring all the way around valve, if it does valve is good,seat can be off and valve will lap in,it will contact highest spot on seat and leave ring all the way around valve.
seat should have ring all the way around seat 360*,if doesn't seat needs to be cut or ground so you have 45* all the way around, will most likely end up wide on one side narrow on other,then take 30* and 60* and narrow 45 until it is even width all the way around,probably .075-.100'' wide. Should be able to lap valve about 30 seconds by hand and it have rings all the way around valve and seat,when correct. Can use machinist dye/layout fluid if needed to see better. Billy, I agree with you most of the time,but I half way disagree on this,exhaust get away with a little leak,intake not gonna get away with much of a leak,with out blowing fuel back up the runners. Or is there more to your comment,like buddy of mine that worked on mowers,came in one day while I was putting seats in a Briggs twin,common for them to fall out,he told me electronic ignition caused that,???? he said when had points,got a set yearly,got all grass cleaned out of cooling fins,electronic doesn't get cleaned out so runs hot seats fall out,LOL Mike Taylor 3601 |
#8 | |
Thanks for all input I think they look pretty good now. Jeff |
