Old 07-08-2016, 07:34 PM   #1
theman440
theman440's Avatar
Liked 24 Times in 13 Posts
Default Bearings?
Does anybody make a bearing to use in place of the lower control arm bushings on Mopars?
Jeff Dudgeon
'66 Coronet #10771 - bracket puke
"the Flying Brick"
theman440 is offline   Reply With Quote
Old 07-08-2016, 08:07 PM   #2
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Default Re: Bearings?
Closest thing I've seen is a grease-able shaft and nylon bushing.
http://www.firmfeel.com/e_body_mopar...able_pins.html
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 07-10-2016, 12:16 PM   #3
Eman
Liked 133 Times in 76 Posts
Ck Afco or Global West. I had a machinist make mine for my Camaro.
Old 07-14-2016, 08:15 PM   #4
theman440
theman440's Avatar
I was aware of the poly & nylon bushings with greasable pins. Looks like this might be the only option. The part that scares me is that the original bushing assy presses in the LCA. The poly bushing just slips inside the old outer shell - so what keeps the LCA from not sliding back off the bushing?
Thanks for the reply.
Jeff Dudgeon
"the Flying Brick"
Old 07-14-2016, 09:37 PM   #5
Frank Bialas
Frank Bialas's Avatar
Liked 24 Times in 14 Posts
Originally Posted by theman440 View Post
does anybody make a bearing to use in place of the lower control arm bushings on mopars?
yes
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
Old 07-15-2016, 10:31 AM   #6
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
The strut rod should keep it from sliding back off.
Patric Fox is offline   Reply With Quote
Old 07-15-2016, 07:55 PM   #7
theman440
theman440's Avatar
Originally Posted by Frank Bialas View Post
yes
Who?
Jeff Dudgeon
"the Flying Brick"
Old 07-16-2016, 11:04 AM   #8
Eman
I don't like poly. They get old,dry and hard and will fall out in chunks when they crack.
