#21 |
no,no,no,no implication of any fault. Just trying to make the point that a
$20,000 work beater has multiple air bags and designed crumple zones, but toter homes and rvs costing many times more ![]() Should we not expect the same attention to safety in our tow rigs. P.S. I use Michelins on our mh and change out the 2 oldest tires every year costs me a couple of bucks but is cheap compared to the cost of a blowout. |
#22 |
Liked 32 Times in 19 Posts
Answer: my MH is a 2008 Showhauler on 2008 Freightliner chassis. I have only replaced Left front as there as a crack developing last year. Now replacing Rt front for early weather checking.
It is always garage kept. Only 37,000 miles. All rear tires look fresh. Pressure stable. Showhauler Motor Homes in Middlebury Indiana is now a dealer for TYRON. Call and ask for Lonnie. He just informed me they are the dealer.. I-574-825-6764. Tell him I mentioned them. They are an outstanding business and build an excellent motorhome. Thanks Dick Butler |
#23 | |
Liked 70 Times in 31 Posts
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#24 |
What brand of system do you have? The Doran system that we sell doesn't require a booster but longer rigs need an external antenna under the motorhome towards the back. We sell the additional sensors for $45 each.
#25 | |
#26 |
Liked 229 Times in 99 Posts
I've got them on my gooseneck trailer and it sends an audible alarm if the pressure goes up or down. If you don't have an alarm you won't know when one of your tires goes on a triple axle.
Floyd Staggs 787 SST |
#27 |
Liked 358 Times in 83 Posts
Yeah, let's ask the motorhome and toterhome manufacturers to incorporate the same safety equipment that cars have. Let's have full cage construction, crumple zones, etc. That will address the 15 crashes a year, where virtually nobody gets killed. It will have a secondary safety benefit, too. Half the people who own motor and toterhomes now wont 'be be able to afford one, because the added safety equipment with push the already insane prices up another 20-30 percent. And don't forget, it's always good to get the Government involved in the lives of it's citizens.
#28 |
I don't know of anything that will tell you that. The system I sell tells you if you have a fast leak, lost sensor, low pressure and high pressure. They say incorrect pressures many times causes blowouts but not always. I've heard that a tire going bad (getting ready to blow) can cause heat build up which equals high pressure. Several years ago after having a tire go flat at night on a triple axle trailer that eventually came apart and done about $1500 damage to my trailer. I did not go on another trip again until I had a tire pressure monitoring system. I've been using one for about 10 years now and have not had another blow out. It takes me about 12 seconds to check the tire pressure on 12 tires.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com Last edited by Darrel Goheen; 03-30-2016 at 06:34 PM. |
#29 |
Good for on the road monitoring of pressure. My friends drove home to Indiana in the dark from Topeka. Never knew it till they got home but only had 3 wheels on their trailer.....
In regard to all the safety issues which would ADD major bucks if required on all.... What if things just are becoming "available" to use for the 15 crashes a year. How about just having them available to people who care? I wonder how many semi crashes or tours of the Median on the interstate are blow outs of the front tires too. |
#30 |
Check out "Steer Safe" Worked great for my Frieghtliner....I wasn't aware they were available for motorhomes.
http://www.steersafe.com/shop/steer-safe-unit
Rick Blake 2395 SG, SC, SP |
