Old 03-13-2016, 05:06 PM   #21
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Windage tray
Hamburger Pans, and I bet Stef's Pans sells pieces of expanded metal screen so you can make your own windage screen . What was interesting is this expanded metal was directional , and acted like thousands of louvers. If you sprayed water at a piece of it in the "wrong direction" the water would bounce back at you. Spray water in the "correct direction" and 99% of the water would pass right through .
Old 03-13-2016, 06:20 PM   #22
V M Kauffman
[QUOTE=ss3011;498185]Hamburger Pans, and I bet Stef's Pans sells pieces of expanded metal screen so you can make your own windage screen . What was interesting is this expanded metal was directional , and acted like thousands of louvers. If you sprayed water at a piece of it in the "wrong direction" the water would bounce back at you. Spray water in the "correct direction" and 99% of the water would pass right through .[/QUOTE
Water is wrong thing to use when testing oil pans, and windage trays only thing it is good for is testing volume oil clings. In wet sump systems it is VERY HARD to get atray that works better than No tray. Worry about a well fiting scraper and large well baffled box with kick out on passengers side and a good pickup that works and doesn't suck a hole in the oil.To test pick up you must use your actual oil.
V M Kauffman is offline   Reply With Quote
Old 03-14-2016, 01:01 PM   #23
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
I use a Moroso 21604 pan on my BBC which is very similar to the 20370 that is popular on a lot of SS big block Chevy's .
I have two versions of this pan ,one with the diamond screen and an earlier one with a louvered tray.......On the same engine with no other changes the louvered tray pan is good for a solid .070 ET and over 1 mph more. This was realized when I took the louvered pan off my spare engine at a race to replace the damaged pan on my engine in the car.
Ishihara -Johnson http://www.crank-scrapers.com/ is the company in Florida that manufacturers scrapers and trays for just about any engine....I found quite a bit of HP on my AMC Stocker using their stuff.
Old 03-14-2016, 03:57 PM   #24
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Tom, was the louvered tray from crankscrapers or was it a Mororso? What rpm range were you in? I've been told that my 7200 rpm's aren't enough to take advantage of a scraper and probably not enough to warrant a tray of any type.
Ron Gusack is offline   Reply With Quote
Old 03-14-2016, 09:08 PM   #25
Chevy55
Banned
Liked 179 Times in 89 Posts
Reher-Morrison Racing Engines
New! BBC Moroso Steel Oil Pan #21049
This BBC Steel oil pan is the best we have seen in all our years of building engines.
http://rehermorrison.com/product/wet-sump-system/
On the dyno, it has shown increased horsepower and steady oil pressure throughout the entire RPM range. This BBC Steel oil pan features a built-in windage tray. It is better at controlling windage, but still fits in dragsters and door slammers. To experience the full benefits of this oil pan, it should be used with the new Moroso oil pump (#22187) and pickup. We offer a combo of the pan and the pump with the pickup. To save time and money, you can also buy the complete wet sump kit featuring this excellent oil pan. See our wet sump section for more information.
Download PDF: More information and dyno test results
Chevy55 is offline   Reply With Quote
Old 03-15-2016, 12:53 PM   #26
Tom Goldman
Ron It was from Moroso . ..I run that engine at 8200 rpm.
