Liked 20 Times in 15 Posts
I started out with a 7" rim [because that is what I have] on a Phoenix F/X 9x28.5 slick. it has a section width of 11". what happens to the section width if I go to a 9" rim? does the diameter change?
thanks Rod in AZ |
Liked 2,463 Times in 695 Posts
Hi Rod: Section width will get around 3/4 Inch Wider ( Possibly close to a inch ).
Height will not change very much at same Air Pressure Tires are happiest when Rim is about the same width as tire footprint on the ground ......give or take a inch or so. See you at LVMS
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 02-07-2016 at 11:35 PM. |
