Old 01-03-2016, 08:11 PM   #101
grncpe
Liked 44 Times in 10 Posts
Default Re: Horsepowers
This was my first year racing in ss. The first thing I don't understand is the fact that you have to beg for anything. Automatic factoring ? Why can't the NHRA mystery computer give hp back at the end of a year? They can doll it out, I would think if there is a combo out there RUNNING that the computer could then give some back. Just thinking out loud. I never went 850 under so it doesn't matter. Just a thought. I should have begged for some since I can't run 1 under or in some cases 1.30 or faster under like some run & nothing happens when they fender you. Great racing there....
Tommy Baker SS/GA # 172
E/SA # 1272
grncpe is offline   Reply With Quote
Old 01-03-2016, 09:20 PM   #102
Tony Janes
It does if you qualify.
Tony Janes 7941 STK, SS
Old 01-04-2016, 12:37 AM   #103
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
Tommy, why would you need horsepower off your combination? Wasn't there an identical combination as yours that could have run a 1.15 under et in the class final of SS/JA? If he can do it, doesn't that give you the indication that the potential of your combination is very good?
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 01-04-2016, 01:18 AM   #104
grncpe
He does not have the same combo I have. He has a Holley carb, I have a avs. Should I change carbs & follow suit? Or stick on my own & work on what I have? I am surprised that you would bring this up though.VIOLATOR! Lol
E/SA # 1272
Old 01-04-2016, 01:26 AM   #105
Sean Cour
Sean Cour's Avatar
Ok, well that must be one hell of a Holley! Lol
Sean Cour
T6066 ladle
Old 01-04-2016, 01:36 AM   #106
grncpe
That's my point. It is almost 100cfm more. Why am I factored the same? It's a different combo. That would be like factoring the lt1 & l98 and all the fi 350 combos together right? I don't see where this an even playing field. I'm not mad at anyone, I don't want it taken the wrong way. That's why I ask questions. IF the NHRA took incremental times into consideration and actually looked at the data they have it would help I think to straighten out the problems with the factoring system.
E/SA # 1272
Old 01-04-2016, 02:20 AM   #107
Sean Cour
Sean Cour's Avatar
Tommy, you're factored the same because at one time or another, someone with your combo was fast. I'm not saying it's a level playing field, but the rules are set, and meant to be manipulated within the current written state.
Sean Cour
T6066 ladle
Old 01-04-2016, 03:12 AM   #108
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Hi Tommy, you're right on with your numbers. The 383 AVS I have flows right at 635 cfm and the 383 Holley 6191 I have is 724 cfm both done on my bench.
Old 01-04-2016, 01:15 PM   #109
Ed Wright
Ed Wright's Avatar
If there are both factored the same, why would you not run the Holley?
Ed Wright 4156 SS/JA
Old 01-04-2016, 01:22 PM   #110
Greg Hill
Liked 279 Times in 68 Posts
Inquiring minds want to know.😊
Greg Hill 4171 STK
