Liked 20 Times in 15 Posts
1.new clean engine going in. what can I use to clean the rust out of the radiator? this is a fairly new core, I dont want to take the tanks off and there is no sonic type cleaners close.
2. assume I get the rad. clean, what can I put in the water to keep the rust under control and still be legal at the strip? 3. what can I use to stop the aluminum corrosion [combo of iron/alum]? 4. what kind of bottle water is best [mine is so hard it will stand up!] any help/ideas? thanks Rod in AZ |
Liked 237 Times in 126 Posts
Use water only. I like the wetting agents that claim to increase cooling efficiency but I can't speak to how legal they are at your tracks.
You need distilled water only, not bottled drinking water. It's on the supermarket shelf in jugs. Distilled water has had all of the minerals that contribute to rust removed by boiling and condensing back to the liquid state. It's what my mother used to use in her steam iron before all this Teflon stuff. Dale
#3 | |
Liked 320 Times in 102 Posts
I have seen Super CJ's with coolant, green in color (anti-freeze) in the surge tanks.... I have been told it's because of the intercooler, but it sounds like BS to me.... Maybe they have been given special dispensation by the NHRA to do whatever they want...... I know that coolant will protect the cooling system but also screw up the track if it spills...... It could also be the Golden Rule......Whoever has the Gold, makes the rules.. Bob
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 12-18-2015 at 01:49 PM. |
#4 | |
Hi, Even with distilled water rust will form..... Rust is Iron Oxide (fe2o3), all you need is water (h2o) or air and iron for rust to form.... Anti-freeze can help, but that's all...... Bob PS: The distilled water in the steam iron was to control the concentration of mineral deposits as the water was converted from liquid to steam and not rust...
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 12-18-2015 at 01:53 PM. |
#5 | |
PS. I thought the minerals in tap water promoted rust. Still use distilled in a race radiator. Dale
Liked 1,923 Times in 578 Posts
I use what ever water comes out of the hose at the house or track. I never leave water in my engine overnight. I drain the engine each night and before I head back home. Just a bit of prevention against a leak and corrosion in the cylinders.
Mike Pearson 2485 SS |
Liked 332 Times in 180 Posts
Wynn's quick cool or Red Line water wetter. We always use sodium silicate or better known as "Water Glass" works great with alum heads will not plug radiators cores either--- Fed 387
Liked 316 Times in 67 Posts
I just examined my 20 year old alum radiator....yuck! We started using distilled a few years ago.
Some recommend an anode (?) One radiator supplier has a recomendation of a series of ground straps (Ron Davis I believe) I'm interested in any other solutions, or if the above two help |
#9 | |
Sample Link: http://www.rotometals.com/product-p/...lite-anode.htm Same thing at Summit: http://www.summitracing.com/search?S...&keyword=anode Also try Radiator Anode on Amazon. Dale
Dale Shearon 68 Mustang 6394 Last edited by FireSale; 12-18-2015 at 07:54 PM. |
If there is rust and/or silicate formation in your radiator, there is nothing on the market that will completely and effectively remove these deposits from your radiator. I was involved in a study (at a major OEM) where we tried all kinds of over the counter solutions as well as solutions that were made up by our chemists. The problem was that you needed the solution to be very aggresive to remove a good portion of the rust/silicate deposits and when it did, the same solution damaged the radiator.
In our race car we run tap water (we have excellent tap water here in Detroit) with a RedLine corrosion inhibitor that has worked well for us. If your current radiator has a fair amount of corrosion build up, I would bite the bullet and replace the radiator because it isn't cooling at peak efficiency and with a brand new engine, I wouldn't take any chances with an old radiator with potential restrictions.
Nelson Kowal Stock 345 |
