#41 |
Liked 9 Times in 8 Posts
Thanks for the suggestions Bill, I have the open tracker double roller perches (nice pieces) don't know what I am using for shocks yet, I may spend the money for custom pieces. I planed to install the bearings in my control arms.
I sent a letter in requesting clarification on this and the cam bearing, as it looks like I started a sh*storm with that...it's better to find out what the deal is sooner than later. What did you use for front springs?
__________________ Bill Diehl B200 C/D STK |
#42 |
Liked 26 Times in 13 Posts
I am not absolutely sure what the front springs are. When I bought the car I am pretty sure that Denny said that they were from a 351 car. It sat a little high in the front and I cut half a coil off them which got the height just about right. I have about 1" of downtravel at rest, perhaps a touch less. Remember, I have a 750 lb chunk of cast iron sitting in there
Bill Harris ex 2172 STK ex 2272 S/S |
#43 |
The boss is lighter...I have access to springs, when I get it all together and scale it I will do the math and put whatever it needs...they may even be dif from side to side
#44 |
Liked 240 Times in 112 Posts
Are you having springs made Bill ? I need to change mine as well but all I've come up with are a pair for a Maverick off of rockauto.com.
Dave Noll, EF/S ,?/SA 6526 |
#45 | |
If you scale the car you can select springs from many places, here is an example http://www.racingsprings.com/Sportsm...ngs/Store/1417 Typical drag race stock suspension front springs are longer with the correct rate to get the ride height set back to standard, as in the case of the mustang aprox 12" without scales and a calculator you are just "guessing" unless you copy something that somebody else already uses (edit, you want to take the free length of the spring and do the math to set ride height...example, 1600 front end weight with 800 on each tire and you want to get to 12" ride height you would need a spring with 16" free length x 200 rate = 12 ride height.....but in the real world the rate increases as the spring is compressed, you would need to take that into the calculations also...and reread the paragraph above this, drag race front springs are usually longer than stock) some springs will be ground flat at both ends so you will need to cut a coil on one end to get a pigtail....you need to figure that into the calculations. Then the best setup would be track test and adjust
__________________ Bill Diehl B200 C/D STK Last edited by Bill Diehl; 11-23-2015 at 09:15 AM. |
#46 |
Got this finally.....the dog is wearing out the UPS man....still waiting for the crossmember, soon the front end will start taking shape
#47 |
If the scale @ our track is right, my Cougar is about 1950lbs. for front weight. As it sits in the garage Im showing 9" long sitting 1" off the bump stop. (Its a little low) So for a 200 rate spring, is that about 14" long free length ? Thanks for the link, did not even think to look there.
Edit: They dont have a 14 so, I guess, start here : PAC-SR16x5x175
Dave Noll, EF/S ,?/SA 6526 Last edited by Dave Noll; 11-24-2015 at 12:04 AM. Reason: New info |
#48 | |
#49 |
The directions are here
#50 |
Look @ all the goodies !!
