#51 |
Liked 19 Times in 12 Posts
Good lord that is sexy! Testing at Milan sunday?
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
#52 |
Liked 408 Times in 35 Posts
If it does not rain.
George Wright https://9500rpm.com |
#53 |
I'll keep my fingers crossed for you.
#54 |
Went out testing at Milan on Friday night.
First run was first and second gear only. Shifter hung up on 2-3 shift. Spun the tires. On the second run I managed to get it in third gear but the shifter hung up going into fourth. I coasted thru the eighth mile with a 6.50 @ 104MPH. Sixty foot was 1.37. I determined that the removable shifter cover was binding against the 3-4 lever on the Jerico. After my second run I headed back to the shop. Besides reworking the removable floor panel I also want to adjust the seat position back a bit, leak down, change plugs and look over my data logs. I hope to go out again next weekend if the weather holds out. Driving out out of my shop. ![]() Loading into the trailer. ![]() Checking the fuel level. ![]() Burnout for my second run. ![]() First run video shot from the starting line behind the car: In car video of the first run:
George Wright https://9500rpm.com Last edited by George Wright; 11-02-2015 at 01:56 AM. Reason: video url |
#55 |
Liked 84 Times in 42 Posts
Wow. When you get the shifter worked out it is going to be very quick.
Bob Tilton 568 FS/H |
#56 |
Good luck George. I'm sure it will be flying in no time.
#57 |
Wow George ! she looks great! I bet you are a proud papa
Sam Monteleone 3348 S/SS |
#58 |
Looks and sounds great George...
#59 |
Made some adjustments to my CJ this week. Moved the seat back, adjusted the shifter, reworked the shifter cover that was rubbing the 3-4 shifter rod and put a Boss 302 alternator on the engine. The other alternator I had on the engine did not line up correctly with the balancer and resulted in the belt getting destroyed.
I went out to Milan this evening and made one pass. I was able to shift all 4 gears and get down the track. Right now the CJ is on FS/G weight. I went 10.20 at 132 MPH. The track was cold so I spun the tires and went 1.45 in sixty foot. Here is an in car video of the run.
#60 | |
Thanks, Mitch.
