Old 07-21-2015, 02:24 PM   #11
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Aftermarket Steering Column
In lieu of the AN4 bolt that Pegasus recommends, use either an MS21250-04016 or NAS6204-16. They are built to the latest specification and 3 times stronger than the AN4 bolt.
The bolts shown above and in the links below, have a 1.0" grip. depending on the diameter of the joint and the spacers, the length may vary.
You can use the AN365-428A nuts at the other end.
You can also procure the fasteners from Aircraft Spruce.
http://www.ebay.com/itm/Close-Tolera...item1e9ff8217b
http://www.ebay.com/itm/1-4-MS21250-...00b5ac&vxp=mtr
Old 07-21-2015, 07:00 PM   #12
SSGT Mustang
Liked 204 Times in 54 Posts
I like the ones with the safety wire holes drilled. I'm a little hesitant about buying those off of ebay. You never know, they could be Chinese knock offs.
Do you know a vendor that comes to mind?
I really appreciate the help. This makes me a whole lot more comfortable with this deal.
SSGT Mustang is offline   Reply With Quote
Old 07-21-2015, 07:07 PM   #13
SSDiv6
I have purchased from both vendors many times and they are aerospace surplus; the real thing.
Have used their bolts in my new Comp Super Modified.
Old 07-21-2015, 07:11 PM   #14
SSGT Mustang
Sounds good. Thanks again.
Old 07-22-2015, 02:32 PM   #15
treessavoy
Liked 4 Times in 4 Posts
This raises a the question: can I replace my entire steering column with an aftermarket column (Idit,or some other manufacturer ) or one from another model of car? I really could use a tilt column to ease getting into the car.
JimR
Jim Rountree
