Old 06-29-2015, 11:01 PM   #31
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
Default Re: FS/H CobraJet Body In White Project
Tail lights, rocker panels, weather stripping all installed.
Door glass installed. Door harness installed and power windows tested.
Seats located and bolted in temporarily. Main wiring harness tested and installed. Big Stuff ECU and electrical components mounted on plate attached to roll cage.
Headlights installed. Gas cylinders installed. No need for a prop rod to hold up the hood.
Deck lid and rear bumper beam installed.
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
Old 06-30-2015, 09:16 AM   #32
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Very nice!
Mitch Beri- The Motor City
Old 06-30-2015, 09:09 PM   #33
Bob1320
Bob1320's Avatar
Thumbs up Re: FS/H CobraJet Body In White Project
Looking very nice and the Mule looks great also...
Bob1320 is offline   Reply With Quote
Old 07-07-2015, 11:43 AM   #34
Sam M
Sam M's Avatar
Wow, George the car looks great! and also congrats for the Mule being #2 qualifier at Norwalk. You two guys are awesome. Can't wait to see this one done!
Sam M is offline   Reply With Quote
Old 07-20-2015, 11:49 PM   #35
George Wright
Latest updates between racing at Norwalk and yesterdays S/SS combo at Milan.
K-member ready to bolt up.
K-member bolted into body. Clutch linkage also bolted in place. Brad Zaskowski built 5 sets of clutch linkage for the stick shift CobraJets we have assembled. Good design and nice workmanship.
Upper 3 link bar and mounting bracket bolted into body.
Rear firewall mocked up with Clecos.
Rear firewall rivited in.
Old 07-21-2015, 09:20 AM   #36
black88coupe
Looks great.
Old 08-11-2015, 11:31 PM   #37
George Wright
More progress on the CJ.
Clutch, brake and gas pedals bolted in. The drive by wire gas pedal was replaced with a fox body gas pedal since I will be using a BigStuff ECU.
Master cylinder installed.
Aeromotive fuel cell installed. Dash 8 hoses being cut and assembled.
Rear brakes assembled.
Moched up with wheels and tires.
Fuel lines installed on the body.
Old 08-12-2015, 08:42 AM   #38
Jay Mingolelli
Very nice build good luck.
Jay Mingolelli is offline   Reply With Quote
Old 09-20-2015, 10:38 PM   #39
George Wright
Getting closer. Lots of little details to finish up. Here some more pictures.
Fitting the BigStuff EFI harness to the engine.
Dashboard bolted in and tach mounted.
9 inch wide Hoosier tires mounted on CobraJet wheels.
I modified the Moroso inline radiator cap so I could pickup up temperature for the BigStuff ECU and the electric water temp gauge. The Coyote cylinder heads don't really have any threaded holes or even any good places to drill and tap a threaded hole to mount a temperature sensor.
I bent and fit two panels to cover and flatten out the back seat area to make it easier to lay a piece of carpet back there.
American Racing Headers moched up on engine. The Lakewood bellhousing is only temporary. I will be using a Browell bellhousing.
Engine set in car for moch up purposes. I will most likely come back out in a few days after I fit the fuel lines from the rails to the regulator and a few other items.
Engine moched up in car.
Engine and drivers side header moched up in car.
Old 09-21-2015, 08:41 AM   #40
black88coupe
Awesome
