Old 06-13-2015, 12:20 PM   #11
REGGIE WINKLES
Liked 39 Times in 9 Posts
Default Re: small bore sbc head gaskets
You have a PM.
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 06-13-2015, 03:49 PM   #12
jimmyparker
Liked 309 Times in 88 Posts
Reggie, you should have an older pm in your box.
Jimmy Parker
jimmyparker is offline   Reply With Quote
Old 07-08-2015, 10:50 AM   #13
1969chevss
So I called SCE gaskets last week. they told me they are starting to make the small bore steel shim head gasket ( 3.950 ) .015 thick equal to the old gm 3995633 part # and should be ready at the end of July. I was also told for the AMC guys out there they also have in stock small bore steel shim head gaskets for the AMC engines as well. Just relaying what they told me.
1969chevss is offline   Reply With Quote
Old 07-08-2015, 11:24 AM   #14
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
It's about time! Thanks for the info.
Old 08-19-2015, 05:19 PM   #15
1969chevss
Yesterday i received my order from SCE Gaskets with the steel shim small bore sbc head gaskets. They are great and fit perfect they have 3.960 bore and .015 thick. if you need some give them a call they are on the shelf and ready to ship.
