running a BBC cast iron head (casting 188) with Comp 947 springs and in order to clear the rocker arms I need to reduce stack height by .045. To get my stack height back should I remove the locator cups completely and just run the springs on top of a .015 shim or should I machine .045 off of the bottom of the locator cups (leaving .015 of thickness). Without cups I have approx. .105 of clearance between the ID of the inner most spring and the od of the valve guide. I do not run seals so clearance between spring and seal is not needed. What are your all thoughts?
Liked 309 Times in 104 Posts
To gain more clearance between retainer and rocker,are you planning on using a -.050 lock which reduces installed height and then removing spring seat or machining it to gain the .050 back in installed height?
If i was doing it and had the room to set spring installed height .050 less I would just put the -.050 lock on it and run more pressure. If don't have the room,if head will locate spring take spring locators/seats out and use .015 shim. Mike Taylor 3601 |
Sounds like you have .560 guides. We do offer a .030" thick spring seat for those springs. Depending on installed height, you may be fine running the -.050" locks and our .030" tick ID locators.
If I can reduce stack height by .045 then my distance to coil bind becomes .064 if I tried .030 I would only have .049 which wouldn't be enough. Thanks for the suggestion though
No problem. I would like to say, you are way better off machining the heads. With the amount of ID and OD clearance you will have, I would not trust that spring on a flat shim. Too much movement available.
Don't cut spring pocket any deeper.
Mike Taylor 3601 |
