Hello all
Well here is a good one for you. Motor starts right up when you start it for the 1st time every day. then for the time run it starts fine, 1st rd it starts fine, 2nd rd it will start right up, then bam 3rd rd it will just spin over and over and not even try to start. Then out of the blue it will fire up, once it stats it will run fine till you cut it off, and try to start it back up. It is really strange, has happened at at leaset the last 3 races. Little info, 522 BBC, pretty standard stuff, 1050, Brodax heads, Dart intake MSD Dist, 7AL2, gas motor. Any ideas? Cal S/ST HR 1177 |
My Camaro had a similar problem but only once. It wouldn't fire sitting in the staging lanes for the final round. I wound it over several times and finally it fired. It was a faulty toggle for the ignition (on/off). Don't know why yours waits till the third round but it is a place to start. Bill
Liked 160 Times in 51 Posts
I would check the coil for proper resistances on the primary and secondary sides and look at heat related ignition issues. Applying some heat with a head gun on the related electronics (box, distributor, coil) can help identify a intermittent part.
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 |
Liked 887 Times in 239 Posts
Ignition switch is a good place to start.
If you have an old style MSD triangular style that is oil filled you might want to check to see if it still has any oil in it . I had one that was nearly empty that gave similar problems and have seen at least two others with the same problem. It seems to be more common if the coil is in the engine compartment.
Liked 1,922 Times in 432 Posts
If it cranks but will not start, as others said, check the ignition switch, the coil, the coil wire, the pick up (what ever style, magnetic or optical, at the crank or in the distributor), and the ignition box.
Alan Roehrich 212A G/S |
Hey Cal it did start 3rd round so it must be getting better, I would leave it alone....lmao
Liked 335 Times in 182 Posts
I would swap out first the coil----what coil and part number are you using?? next swap out the ignition box-- what box and part number are you using--- FED 387
#8 | |
Liked 118 Times in 41 Posts
Liked 11 Times in 8 Posts
WOW I've never heard of many switch failures till now...however here's what I'd do to eliminate that as a source of the problem. If box is easily accesible put a volt meter in car, when issue arises simply test for voltage on the IGNITION point on the box should be battery voltage.If box is not easily accessed put a short lead on Ignition terminal of box with insulated end, then do the same test as quickly as possible as it appears the issue resolves itself.Other option is to zip tie, duct tape, velcro meter in car already hooked up and merely switch on as needed to test.Personally to quickly narrow down the issue I would use my MSD tester to quickly rule out a non funtional crank sensor, test the ability to fire the coil ect. Good luck and let us know what you find. Joe
Joe Buchanan SS/BX 3117 |
Liked 319 Times in 108 Posts
If starter solenoid has the extra post could run wire from it to + side of coil,will send 12 volts to coil while cranking.
Mike Taylor 3601 |
