Liked 99 Times in 49 Posts
Parked the car last fall everything is fine, Start it yesterday and now when you click it off it runs for several second before it shut off. I have checked the grounds, does not have a alternater, When I put a test light on the ing switch it stops like it should .Has a ARC switch panel. Anyone Jim Hanig
#2 | |
Liked 684 Times in 289 Posts
With the engine idling, you could unplug the ign. box to kill it. Should stall immediately That should point the way Turn the key off before you plug it back in. I don't believe you would damage your particular ign. system, but you will have to decide that. Good luck Mike A114 P/SA Last edited by Mike Jones; 05-24-2015 at 11:38 AM. |
Liked 20 Times in 9 Posts
Electric fan backfeed? No relay?
Liked 54 Times in 33 Posts
Fresh fuel? Race gas dies quickly compared to street pump gas. Had this experience 25 years ago.
The fuel is a week old
Does the panel need to be grounded? It is screwed to the plastic dash ?
Liked 288 Times in 90 Posts
Jim
Just had the same happen to me after doing a cam swap. I normally kill the motor by shuting off the fuel pump, never had a problem until then. Engine slowly loses rpm put stays running for 10 seconds. Fuel pressure is slowing dropping from 65psi but still registers on regulator. What brand of fuel are you running??? RJ |
Liked 49 Times in 15 Posts
Jim, did you check the relay? The contacts may have corroded over the winter and then it may have welded itself on during the first use.
Dean Feiock -- Stock 5002 |
Well heres one for you I got al set to redo the wireing ,start the car and guess what it quit s like it suppose to.
