Old 05-22-2015, 08:28 PM   #11
Run to Rund
Liked 54 Times in 27 Posts
Default Re: Seat Weight
66 Olds F85 front bench weighs 74 lb.
Old 05-23-2015, 03:50 PM   #12
Jim Carter
Liked 19 Times in 3 Posts
Smile Re: Seat Weight
Originally Posted by treessavoy View Post
My '64 Savoy will keep it's bench seat for that same reason...they look like some roundy round crap, plus I would have to change my roll bar because the new seats put me more than 6" away from the bar.
JimR
I believe Kirkey makes a bracket/spacer to fill that 6" void. I prefer the stock seats also,but it is hard to ignore the benefit of moving 40-50 lbs. to the weight box. Especially with a iron headed big block up front. Speaking of weight shifting, all the Camaros that were made to remove the cowl induction hood lost 30 lbs. off their nose.
Jim Carter is offline   Reply With Quote
Old 05-23-2015, 03:59 PM   #13
Jim Carter
Originally Posted by Lew Silverman View Post
The Model 41500 weighs 12.1 pounds.
Wasn't the original idea behind the rules change because the newer seats were "safer"?
https://www.kirkeyracing.com/related...op-drawing.jpg
Lew:
Does that include the weight of the mounting rails, hardware and covering?
