Old 04-27-2015, 06:28 PM   #11
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: 283 stocker timing problems
Your first step should be to put the engine at TDC (with a degree wheel & stop) and check if the tab lines up with the balancer for TDC.............
Too many variables at this point to troubleshoot this hard crank & start problem....
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 04-27-2015, 08:14 PM   #12
Terry Waldron
Nothing is different than last year, had motor out to change oil pan gasket that was leaking, have 2 batteries mini starter, all the same as last year, timing marks are right on with TDC. I will pull the dist. again and reset it maybe I am off somewhere.
Terry Waldron 5619 K/S
Terry Waldron is offline   Reply With Quote
Old 04-28-2015, 08:52 AM   #13
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
When you had engine out if you put fresh coat of paint on it,take starter off and scrape paint off where starter mounts,seen that a few times.
Mike Taylor 3601
Old 04-28-2015, 12:24 PM   #14
Liked 5,125 Times in 1,953 Posts
Wink Re: 283 stocker timing problems
Mike Taylor 3601
Yes...Also the ground connection to the block.
I know it sounds basic but it happens...Trust me.
Old 05-01-2015, 08:20 PM   #15
Terry Waldron
Thumbs up Re: 283 stocker timing problems
Just to let you know got it all fixed, battery showed a good charge all the time but when i went to start it was not enough, battery was 4 yrs old did not realize that, thanks for the comments.
