So I'm trying to figure why I lost 3 to 5 mph. Plugs are black that usually are a nice brown. carb is not dumping and my AF meter says super rich. Drop some jets no change. Could the coil not be putting out enough power. I just tested it with meter. Its a digital 6 box with a Blaster HVC ll 8253 coil. It had .07 ohms across primary terminals and .739k ohms from positive terminal to coil post.
Liked 30 Times in 17 Posts
Clean out your high speed air bleeds
I have had the HVC II coils (Red and Blue) malfunction sometimes without
any warning. I would try to borrow a Blue one from someone and try it a pass. Even when bad........They check OK at MSD trailer but MPH falls off 5 sometimes more!
Thanks guys. I'll look into the carb and I will borrow a coil from my brother and give it a try. Hopefully thats the problem. I want the mph back.
