Liked 7 Times in 5 Posts
I,m building a 4th gen Camaro ,I have a 350/330 crate motor now but hope to put in a lt1 in the future. The headers I have are 3 1/2 out . Are they too big for my application ?
What is your stall speed.
Liked 1,952 Times in 439 Posts
Mike, what you need is Larry Meaux's PipeMax software. It will help you choose the best possible header for your combination. Look for MaxRace Software. Best money you'll spend, pays for itself on the first set of headers you buy. Tell Larry I sent you.
Alan Roehrich 212A G/S |
Stalls around 5500.
Allen I will ck him out thanks |
Mike, Your primary tubes should be 1 7/5 inches. The collectors should be 2 1/2 inches. If you use a merge collector the 2 1/2 inches should be the minor diameter. The major, or larger size, can be almost any size you want. I know this sounds awfully small but we set national records with this formula. If you don't think it works just bolt a street reducer on your 3 1/2 collectors [3 1/2 to 2 1/2] and see what happens. This the cheapest way and I think you will be be surprised. Hope this helps and good luck.
Dmir55. Check your PM
Mike I am sorry old fingers and key boards don't mix. The primary tube size should be 1 3/4. sorry about that.
Liked 33 Times in 16 Posts
We knew what you meant.
Rich Taylor I/SA - 321 |
