Old 02-23-2015, 09:09 PM   #11
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Default Re: Cylinder Head Issues
Somebody on Class Racer used to sell header plugs that had the moisture absorbing crystals inside, maybe someone on here remembers who was selling them.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 02-23-2015, 09:19 PM   #12
JHeath
JHeath's Avatar
Dan Dvorak was the racer who made them.
Jerry Heath
I/S '93 Cobra
Old 02-24-2015, 09:53 AM   #13
terry1
Liked 24 Times in 13 Posts
Mike, Canadian Tire do sell a fogging oil.I used it last fall.I my have to bone up on my
procedure though.
Terry K
terry1 is offline   Reply With Quote
Old 03-09-2015, 10:23 PM   #14
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Cylinder Head Issues
Thank you one and all for sharing your knowledge. This bunch of racers has more experiential knowledge of what works and what doesn't than any body else could imagine. I got the heads down to bare castings,the intakes all look great, all but two of the exhaust seats need help. I plan to reface them , lightly touch the valves, new seals, and new springs. Now, with a 327,250 horse, 1.72 intakes,1.500 exhausts, Elgin rockers, not rollers yet, new Comp springs,what spring tension should I go for?I was thinking 350 over the nose, 180 on the seat. This engine is done by 7000,so i wasn't going for broke on the spring pressures.If it was a 275 horse with roller rockers, that would be different. This engine does have a steel Bullet cam and Smith lifters. Wouldn't it be great if we could run a rev kit on a stocker motor? Just thinking.
Old 03-09-2015, 11:58 PM   #15
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
I run 160 on the seat with comp springs, done a back to back test at the track and boosted them up to .050 before coil bind, which I believe was around 200 on the seat. It ran about the same. I put them back to 160. This was on a 295 hp 350.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 03-10-2015, 10:33 AM   #16
Doug McCue
Liked 13 Times in 2 Posts
Originally Posted by Mike Semeniuk View Post
Terry,
Canadian Tire did sell Marvel Mystery Oil out here in the west not sure if they still do. There is also a CRC aerosol product the motorcycle guys use but then you would have to pull plugs and spray the cylinders. Might need to go south and buy a couple of cases of Marvel. I bought 3 cases 6 years ago and only have one can left.
Orielly's sell Marvel Mystery Oil
Doug McCue is offline   Reply With Quote
Old 03-11-2015, 12:52 PM   #17
Kegracing
Nerf balls make great header plugs. They make lot of different sizes of little footballs and other balls. Cheap and easy to find at WalMart, etc. Also wont hurt much if you crank it over and forget to pull them out... they just shoot out of the headers. Might have to chase them down.
Let the pipes cool before sticking the balls into the pipes.
Good luck.
Ken
Stock 412
Kegracing is offline   Reply With Quote
Old 03-11-2015, 05:34 PM   #18
FED 387
Liked 334 Times in 181 Posts
Fogging the motor when not in use as well as plugging the collectors works great--- we also replace the spark plugs with dessicant plugs at the end of each day to control moisture in the cylinders-- FED 387
